Pacific power transformer layout
harris51
Post by harris51 »
anybody know the the color code to these power trannys? Im building a liverpool, any help would be great, Thanks
Randy Magee
Re: Pacific power transformer layout
Post by Randy Magee »
RJ has the schematics on his website...
http://www.rjguitars.net/Pacific_Transformers.html
Randy Magee
harris51
Post by harris51 »
the wires: Coming for one side 2browns 2 blacks 2 reds 2yellow 1white/brown stripe 1 yellow/red stripe 2yellow/green stripes
RJ's doesnt show the reds
anybody know the hook up
I'd bet the yellow/red stripe is the CT, so hook up the primary and measure from one each a red, yellow, and a yellow/green to the yellow red. Separate the leads between two pieces of masking tape to keep things "orderly."
Last edited by martin manning on Fri May 18, 2012 10:40 am, edited 1 time in total.
Sounds like you have an Edcor not a Pacific PT.
harris51
Post by harris51 »
no it 's a pacific talked to Sean from Pacific today.he send over a voltage read out that makes no sense to me.
harris51 wrote:the wires: Coming for one side 2browns 2 blacks 2 reds 2yellow 1white/brown stripe 1 yellow/red stripe 2yellow/green stripes
My guess is:
Primary is two black wires
Two red wires are secondary HT yellow/red is CT (hghest voltage)
Two yellow/green stripes is secondary HT (lower voltage)
Two yellow wires are 5v tap no CT
Two brown are 6.3v tap and white/brown CT
But I would get ahold of rj or Pacific
I think that may be it Mark, and that would be pretty much standard color coding. On the Pacific I just got from rj one set of HT's are plain yellow, but I don't think this is one of his. If the yellow wires are heavier gauge that would tend to confirm that they are 5V. I'd just do some continuity checks to separate the windings, power it up, and measure the voltages.
harris51
Thank everyone for your help
Post by harris51 »
if anyone has a layout that would help even more
What did you get from Pacific?
RJ Guitars
Post by RJ Guitars »
Yes there are many possibilities but with only a few rare deviations, the Pacific's for Trainwreck builds use the wiring diagram that Randy's note pointed to earlier in this thread -- http://www.rjguitars.net/Digital_Images/Pacific_PT.jpg
Edcor transformers are typically Blue with the exception of a few of them I custom ordered recently that have gray end bells. I also know that a few Pacifics have been around that also use gray end bells but everything I sell from them is black. I've never seen anything but Black end bells on the Heyboers, although it's possible that any of them could be painted any color.
One other "standard" is that most of the Trainwreck Tranny makers use black for the mains wiring. If you can confirm this then power up the tranny it will allow you to measure what is what before you start cutting and soldering wires.
rj
I waiting to hear what Pacific says or show the info Pacific sent you.
harris51
I'll post that info Sunday night. Thanks
Post by harris51 »
Out of town thanks for all the help,guys
harris51
Post by harris51 »
pacific color chart any way of telling me where these wire hook up?
rhinson
Post by rhinson »
it's just like the diagram in rj's reply. except the addition of a 5v winding for 5v tube rect. heaters. rh
