Rocket help - Easy I think
yalesmith
Post by yalesmith »
First, I must say I am not too familiar with chokes and rectifiers...but I did build a tweed once. My problem is I cant get any heater/cathode voltages on the rectifiers, the plates are okay at 294 ac. Aqny ideas?
As far as the choke is concerned, am i correct in thinking that a choke acts as nothing but a big resistor? meaning that it doesn't matter how it is wired up.... do the colors of the leads matter?
I am using Edcor Irons.
Any help would be appreciated.
Re: Rocket help - Easy I think
Can you post photos?
guitarsnguns04
Post by guitarsnguns04 »
+1 Post a couple of pics
yalesmith
Post by yalesmith »
how do you post pics? i just searched for instructions with no luck. how do you?
thanks
File name ....... Browse ] use the browse button to search your picture files then click on the picture you want to upload.
Then click on the button that says add attachment and wait for it to load.
Once it has been accepted click submit and your done.
yalesmith
Post by yalesmith »
here you go...for some reason i though u could not upload directly to the site...sorry
yalesmith
Post by yalesmith »
second pic
I don't see where your rectifier pin 8 is wired to the main filter caps?
surfsup
Post by surfsup »
Arent pins 2 4 6 and 8 supposed to be used? Looks like 1 3 5 and 7 but my phone wont let me download the pics so i cant see em that good.
guitarsnguns04
After zooming in on that second pic I think I see the center post on your rectifier tube....if I'm seeing it right looking into the chassis with the center pin at the top all your connections need to be connected to the pin 1 clockwise of where they are now.....ex yellows on 2 and 8 and reds on 4 and 6 ....your white b+ white wire will be on pin 8 also .. Hope I'm seeing this right
Last edited by guitarsnguns04 on Sun Mar 11, 2012 12:41 am, edited 1 time in total.
LeftyStrat
Post by LeftyStrat »
surfsup wrote:Arent pins 2 4 6 and 8 supposed to be used? Looks like 1 3 5 and 7 but my phone wont let me download the pics so i cant see em that good.
That's what it looks like to me also.
guitarsnguns04
Surfs up...you must have posted while I was typing...damn iPad...lol
Yeah I can't get a good view but it sure looks like the index is straight up so all the pins are off then.
sunnydaze
Post by sunnydaze »
guitarsnguns04 wrote:After zooming in on that second pic I think I see the center post on your rectifier tube....if I'm seeing it right looking into the chassis with the center pin at the top all your connections need to be connected to the pin 1 clockwise of where they are now.....ex yellows on 2 and 8 and reds on 4 and 6 ....your white b+ white wire will be on pin 8 also .. Hope I'm seeing this right
The first pic is clearer than the second. If you zoom in on that, can read the numbers on the socket. It looks like the cathodes and plates are wired correctly (2 & 8) and (4 & 6) based on the socket numbers. It looks like the tube is inserted incorrectly based on the orientation of the "key". If the tube were inserted so that the key were one spot counter clockwise, looks ok to me.
Except for Mark's point - I can't see where the rectifier is wired to the resorvoir caps.
Mike
Sunnydaze
Mike
It looks like the yellow wires are soldered to pin 1 and 7 when I look at the rectifier socket and yes I don't see the rectifier wired to the filter caps.
