I am having some success in the "chasing down the bloom department" by increasing the bias in my output section. Tony is running output tubes with 35 watt plates which makes it relatively easy for him to bias up at 48ma's. I am sitting at 135uf on B+1 (270uf in series). I pushed my bias up to 47ma's on my hottest tube, running TAD 6L6WGC's, which is right at 70%. Installed Amperex tubes in V1 and V2 and a GE longplate in V3. I can now hang on a note and at higher volumes , in overdrive, am starting to bloom just before feedback. I think upping the output bias coupled with a lower B+1 capacitor is the key here. Also adding the extra stage with the dumbleator Helps I'm sure. I have noticed this effect in other designs I've built and it seems to coincide, to some degree, with my penchant for driving my output tubes really hard in a high gain situation.
Tony, I'm curious, with my 4 output tubes sitting there idling at 47 ma's apiece I'm eating up half the power of my PT and the amp is running noticeably hotter. Have you noticed the heat out of your transformers?
My #102 Review
Re: My #102 Review
"It Happens"
Forrest Gump
Forrest Gump
Re: My #102 Review
Passfan
yes I have noticed my PT running a bit hotter on this build..
I want to experiment around with different output tubes later in the week..
All The Best
All The Best
Re: My #102 Review
Another spliced Music Man..
Re: My #102 Review
I just picked up a matched quad of Sylvania STR 387's for the amp..Promise to post clips real soon!!
Re: My #102 Review
I think it's safe to say this particular Dumble amp has used iron..
BTW.. Dont take this post seriously..Making a JOKE!!
Re: My #102 Review
Here is another..Spliced output transformer
Re: My #102 Review
Spliced power transformer and BTW 50uf on the plates
Re: My #102 Review
I was looking for the layout and schematic for this build i thought i had seen them but cant seem to find them now.
Have they been removed if so could anyone let me have a copy?
amplifiednation
Re: My #102 Review
Amplified Nation
www.amplifiednation.com
@ampnation
@ampnation
