Cathode Bypass Caps
Frostbite Slim
Cathode Bypass Caps
Post by Frostbite Slim »
What are the preferred cap brand for the cathode bypass caps for Dumble (ODS) builds? I haven't seen any spragues, but ones that are maybe Philips BC?
ToneMerc
Re: Cathode Bypass Caps
Post by ToneMerc »
I've seen quite a few builds here with what looks like Nichicon and then Sprague TVA ocassionally. I like to use the Sprague TE and 501D series as well and I have used Phillips BC too.
TM
jelle
Post by jelle »
I have seen both Sprague TE and Nichicon in Dumbles. I would not be surprised if he used many more types. Draw your conclusions.... :D
ToneMerc
Post by ToneMerc »
TE's here.
TM
briane
Post by briane »
nichicon for me.
cheap and work great.
jestaudio
Post by jestaudio »
briane wrote:nichicon for me.
a mixture of sprague and nichicon in my build
ToneMerc
Post by ToneMerc »
jelle wrote:I have seen both Sprague TE and Nichicon in Dumbles. I would not be surprised if he used many more types. Draw your conclusions.... :D
Jelle from what I've seen HAD used whatever his runner grabbed for him.
TM
Frostbite Slim
Think I'll give the Sprauge TE's a try....Thanks.
Frostbite Slim
So what are the most common values for the Clean channel. I've seen some with 4.7uf and others 10uf.
jelle
Post by jelle »
Most common is 4.7 uf. Have fun! Jelle
talbany
Post by talbany »
Building a 102. Got Nich's
Sweet looking build Tony.
I look forward to your impression of it once you try it.
backpack
Post by backpack »
Looks clean to me. I like the elevated heater wires as well.
jelle
Post by jelle »
Tony, are those the metal films I sent you that are now on plate and cathode?
talbany
Post by talbany »
jelle wrote:Tony, are those the metal films I sent you that are now on plate and cathode?
Jelle
Sure are. The Phiers were Also graciously donated by Tonemerc. The chassis is Bills (windham) and opt is from Eric.(NOS Bassman 100) and going in a Taylor head cab.So this sort of an amp garage community build. Looking forward to firing this beast up and adding it to my Stable
