A new source for cheap toroidal PTs?
LeftyStrat
Post by LeftyStrat »
Has anyone purchased transformers from these guys:
https://www.antekinc.com
Check out this:
https://www.antekinc.com/details.php?p=72
300VA
325V .45A
6.3V 4A
For $40!
Is this for real?
Re: A new source for cheap toroidal PTs?
Well I know that it is cheaper to manufacture toroidals that standard PT's.
So it might be possible
LeftyStrat
cbass wrote:Well I know that it is cheaper to manufacture toroidals that standard PT's.
Yeah, but it seems every source I found charges a premium for high voltage ones typically used in tube amps. An equivalent Plitron costs more than $300.
soma_hero
Post by soma_hero »
Yeah they're popular for hifi builds. I made a chip amp with one, and recently got one for a gibson clone build. Cheap cheap, but the quality is outstanding!
soma_hero wrote:Yeah they're popular for hifi builds.
Thats why they're so expensive
Luthierwnc
Post by Luthierwnc »
I've built two Dumbleators using the 0-260/280 50VA version. Works great, quiet, cool to the touch and, in this case, exactly the right height for a 1U app. Having two heater taps is nice for relays. Thumbs up for light-duty builds -- can't comment on power tube uses. Skip
LeftyStrat
Well I just ordered one. I will report back when I get it.
katopan
Post by katopan »
People are using them for cheap builds with great sucess over at the Wattkins forum.
Cliff Schecht
Post by Cliff Schecht »
I love their stuff. It's beefy, stays cool and is super quiet. I put an AX7 maybe 1" away from the PT and that amp didn't have any noise problems. The best part is the price of course! They make a PT that is great in an Express.
Cliff Schecht - Circuit P.I.
renshen1957
Post by renshen1957 »
LeftyStrat wrote:Has anyone purchased transformers from these guys:
Check out this:
300VA
325V .45A
6.3V 4A
For $40!
Is this for real?
Hi,
I've purchase a toroid power amplifier (would power a Twin Reverb and with reserve power) from antekinc through Ebay.com.
Excellent value, overbuilt, and well worth the price and more paid for it.
Very low EMF radiation.
I haven't tried a Toroid Output transformer, yet. Maybe for a Hi-Fi build.
For a good value in EI Transformers, Edcorusa.com offers power and output transformers at a reasonable price, too. M6 Steel, wound with the virgin copper magnet insulated wire (UL standards). I will be buying from them now that Hammond has gotten expensive for their Classic Formers.
Best Regards,
Steve,
PS Hammonds filament and other small step-down transformers I have recently purchased have a "Made in China" sticker on them. I don't have an issue with some Chinese products, but I would expect lower prices for said items or at least not a made in North America price.
First Rant of the New Year.
VacuumVoodoo
Post by VacuumVoodoo »
40$ for a toroid PT is cheap.
No protective screen between primary and secondary winding.
No external GOSS magnetic shield.
Rather poor load regulation (for a toroid PT) of 8.5% says they made savings on copper and allowed ca 4A/mm^2 current density against industry standard 2.5A/mm^2. One goes toroid because it easily allows load regulation of 5% and better. This puts their claim of "heavier wire gauge and lower copper losses" under heavy scrutiny.
Because of the above I'm out.
But I give them thumbs up for testing isolation at 4kV.
You get what you pay for.
Aleksander Niemand
affiliation:TUBEWONDER AMPS
Zagray!-review
Paul Fawcett
Post by Paul Fawcett »
Check out this:
300VA
325V .45A
6.3V 4A
For $40!
Is this for real?
I have used this transformer with great success in a 4x6L6 Dumble-ish kind of build and will soon be doing so again. With SS recto and typical bias (and somewhat power hungry 6 tube preamp) I end up with about 425VDC B+, no sign of thermal stress of any kind. Incidentally, I built this amp in the US for 60hz 120VAC, but ultimately rewired it and shipped it to Switzerland, and it is working fine also at 50hz/230VAC.
EDIT: Not sure if it matters, but I should mention that in my amp I am using only one of the 6.3VAC taps, as the preamp tubes are on regulated DC from a dedicated tranny. Note that the 6.3VAC taps are 4A *each*, not total.
katopan
Post by katopan »
Experience of others that I've read is that the regulation isn't as good as other transformers. But in the applications where the HT winding is nicely oversized for what you're using in the amp, they work fine and run very cool. On paper technically more PT than you need, but cheap and they do the job fine.
passfan
Post by passfan »
VacuumVoodoo wrote:40$ for a toroid PT is cheap.
A couple of models higher up have the features you list and come in around the 50 to 60 dollar range.
"It Happens"
Forrest Gump
LeftyStrat
I received the transformer. Seems pretty heavy, I was hoping for a bit more weight savings over a traditional transformer. But I plan on using it in my next build.
