A Mix of #0060 OD100WR/ #183
67plexi
Post by 67plexi »
The preamp of #0060 OD100WR and the rest is #183
It will have a single tube reverb with a ½ power switch.
I wanted to go with the 3 tube reverb but the chassis is 7” to short.
Have a combo cab for this chassis. It’s going slow………………
Soon to order a Drake 1202-32 OPT and replace the Magnetic components OPT.
Thanks to all, Steve.
67plexi
Post by 67plexi »
It's a mess now.
jelle
Re: A Mix of #0060 OD100WR/ #183
Post by jelle »
Great start. One thing confuses me...183 and lnfb on v1b? Where will you put the four reverb controls that sn 60 has? Love the nos parts. 8)
dreric
Post by dreric »
jelle wrote:Great start. One thing confuses me...183 and lnfb on v1b? Where will you put the four reverb controls that sn 60 has? Love the nos parts. 8)
Cool rehab of a build.
Jelle, care to elaborate on the 4 control reverb? Tone, volume, dwell...........?
Eric
jelle
Post by jelle »
Honestly...dunno 100% sure how sn 60 works. I'd love to meet that amp. But I'm sure it's an improvement over the earlier ODRS amps in terms of reverb implementation.
Jelle
Max
Post by Max »
jelle wrote:Honestly...dunno 100% sure how sn 60 works. I'd love to meet that amp. But I'm sure it's an improvement over the earlier ODRS amps in terms of reverb implementation.
Jelle, IMO it's no "improvement" in the sense of "better", but just a different approach with advantages and disadvantages (as so often in the realm of technology):
With of course some simplification you could perhaps think of the OD sound of the older pre OD reverb topology as beeing a bit similar to a Deluxe Reverb or a Fender stand alone reverb unit in front of a Tweed Deluxe that are cranked to deliver power amp distortion harmonics and sustain. As you'll know in this configuration the reverb will get the more prominent in the texture of the clipping tone the more the tone decays, a bit similar to a ducking effect.
With the later post OD reverb topology, the spring reverb - again with some simplification - acts more or less like any other effect in the loop.
AFAIK ODR #060 doesn't have four reverb controls but the usual two (send and return), but it has two ratios (clean and overdrive). And - again with some simplification - you could perhaps think of these two ratios as acting like two seperate send controls in front of the "send" control: http://www.premierguitar.com/Magazine/I ... 100WR.aspx
Max
ampdork
Post by ampdork »
I like the post preamp reverb Dumble did as a mod for a few amps. Without question it more closely follows nature.
"...& I'm all out of bubblegum"
Max
Post by Max »
ampdork wrote:I like the post preamp reverb Dumble did as a mod for a few amps.
AFAIK most of the post OD ODR amps aren't pre OD ODRS amps that have been modded but have been originally built by Alexander Dumble with the post OD topology.
ampdork wrote:Without question it more closely follows nature.
IMO most opinions can be questioned - this one beeing no exception. Or can you really name some reasons beyond any doubt why the post OD reverb of ODR #060 is more in accord with "nature" (?) than the pre OD reverb of a Jim Kelley 30/60 or FACS or a Dumble ODRS like this one: https://tubeamparchive.com/viewtopic.ph ... 952#188952 ?
Max
67plexi
Post by 67plexi »
Clean ratio and overdrive ratio. Let you all know how it turns out.
Steve.
ampdork
Post by ampdork »
OK max so your saying that time based effects put before an amp has no bearing on sound. Either sounds equally "natural" to you?
Look...fine... It is only my opinion....and the opinion of every manufacturer of a time based effects and the opinion of damn near all sound engineers...
Max do you also think Stereo is natural sounding?
Max
Post by Max »
ampdork wrote:Either sounds equally "natural" to you?
Natural: I didn't pick up the electric guitar because I'm interested in "natural" sounds. I'm a great fan of completely artificial human made music (Hendrix, Stockhausen, Zappa, Bach etc.) performed with completely artificial human made devices like violins or Steel String Singers. Of course I like the sounds of nature. But if I want to listen to the natural sound a waterfall, I would just visit the place where it is.
So IMO a pre OD reverb ODSR amp and a post OD reverb ODR amp are just two differrent musical instruments. And to say that the later ODR is "better" or an "improvement" IMO doesn't make more sense than to say that a modern trumpet is "better" than a baroque trumpet.
Stereo and High Fidelity: IMO just clever marketing ideas. IMO trying to reproduce the ambience of Covent Garden in a living room is a nonsense approach. But of course I'm aware that my opinions concerning this aren't the mainstream ones.
Max
boldaslove6789
Post by boldaslove6789 »
Looks great Steve! Gonna be a tight fit huh.
I hope to start stock piling parts for my 100w SSS with the 3 tube ODR Reverb, too bad ya didn't have room, I hear it kicks A$$.
67plexi
Post by 67plexi »
Greg, I don’t think the reverb can be crammed or shoe horned in this chassis.
I will have to use an outboard unit. As far as the SSS 3 tube reverb sounds interesting.
The SSS NOS parts are expensive.
Take care,Steve.
67plexi
Post by 67plexi »
Thanks’ to Robert Hinson for the ultra fast shipping.
This Drake 1202-132 clone (the black flag) OPT is larger than the PT.
Should deliver the clean head room I’m looking for.
Steve. :D
passfan
Post by passfan »
A heads up on your half power switch. Toggles switch differently than sliders. If your layout diagram shows a slider and you wired a toggle the exact same way your switching and LED will be backwards.
"It Happens"
Forrest Gump
