I just completed my 50 watt D style ODS
Re: I just completed my 50 watt D style ODS
I'm going to take a break from the amp manufacturing for a while. With the bad economy I'm not really selling any amps this year.
						- David Root
Very professional build! After 50 it should be! I've only built four but each one gets better.
My 50W is a hybrid of #13 and #40 and it sounds wonderful. I put old iron in it ('67 Bassman), but I'm interested by what you say about liking the MM iron and not liking the MC iron. I've used both and I like both, but what specifically about the MC iron don't you like?
To my ears the MM has a warmer rounder tone than the MC.
I am curious about this too... in this comparison were the amps otherwise identical?leleduke wrote:To my ears the MM has a warmer rounder tone than the MC.
Same circuit based on 124martin manning wrote:I am curious about this too... in this comparison were the amps otherwise identical?leleduke wrote:To my ears the MM has a warmer rounder tone than the MC.
blue monkey od eq
Hi from Turkey,
I have a BN blue monkey, for the drive section what should be the value of the trim caps for mid, bass and the treble? i know i am sounding a little ignorant. I need your help but I am not sure if I made myself clear.
Thnx
Mustafa
Thnx
Mustafa
Re: blue monkey od eq
250Kmegemen wrote:Hi from Turkey,
Thnx
Mustafa
Try these settingsmegemen wrote:Hi from Turkey,
Thnx
Mustafa
OD trimmer - 25K
Bass trimmer - 75K
Mid trimmer - 6K
Treble trimmer - 90K
TM
Hi all, thnx for the info.
But Leleduke says 250K, Tonemerc says
OD trimmer - 25K
Bass trimmer - 75K
Mid trimmer - 6K
what is what?
all the best
Mustrafa
OD trimmer - 25K
Bass trimmer - 75K
Mid trimmer - 6K
what is what?
all the best
Mustrafa
