Peavey Donor amp build
Re: Peavey Donor amp build
Oh, and lose the cap C1
				dcribbs1412
Will do Bob..and report backBob-I wrote:Cap off the low voltage tap and connect only the high voltage tap to the bridge rectifier. Nothing from the PT secondary taps get grounded.
Darin
				dcribbs1412
Ok when I cap the high voltage CT tap(R/Y wire) I get nothing on the bias.No soundBob-I wrote:Cap off the low voltage tap and connect only the high voltage tap to the bridge rectifier. Nothing from the PT secondary taps get grounded.
when I ground the HV CT tap amp works but I only get 250V
any suggestions
Darin
Just to be clear, you should have the lead from the fuse to one side of the bridge, the red (hi) lead to the other side, the bridge ground is is solid and the B+ leadnshows nothing?dcribbs1412 wrote:Ok when I cap the low voltage tap I get nothing on the bias.No soundBob-I wrote:Cap off the low voltage tap and connect only the high voltage tap to the bridge rectifier. Nothing from the PT secondary taps get grounded.
when I ground the LV tap amp works but I only get 250V
any suggestions
Darin
Measure the AC across secondary leads.
				dcribbs1412
Bob
appreciate your time
not sure I'm following you
here's a pic of what I have now.... 2 Red HV taps to diodes splits to bias
R/Y CT is to ground with filter caps
380V across leads
380V across leads
Ok, that's a full wave rectifier, not a bridge.
Double check the schematic.
				dcribbs1412
Thanks BobBob-I wrote:Ok, that's a full wave rectifier, not a bridge.
I'll do some research and see if i can wrap my head around a bridge
I gotta say the amp sounds decent as is, but I know its not right
bummer to stall so close to the end.
Thanks for your time
Darin
If I remeber correctely on these transformers you can use a bridge rectifier on the orange taps to get around -50vdc for your bias.
http://www.hammondmfg.com/pdf/5c007.pdf
This link may help clear things up
				dcribbs1412
Thanks cbasscbass wrote:If I remeber correctely on these transformers you can use a bridge rectifier on the orange taps to get around -50vdc for your bias.
I'll need to figure out which to use...I do have a choke on this build
was hoping to use the orange taps down the road for relays.
Appreciate your time
Darin
You'll want to use the full wave bridge capacito rinput.
Third one down on right
				dcribbs1412
Got it... I have 520V now but the bias went wild.Wondering if a changecbass wrote:You'll want to use the full wave bridge capacito rinput.
of resistor value up from 56k to say 220k would work.Or I need to rework the bias circuit like a marshall (jcm900).
Darin
Glad to hear you got it. Yes, try the 220k. You could get crazy and calculate the voltage divider values, or you could swap the resistor and take a wag.dcribbs1412 wrote:Got it... I have 520V now but the bias went wild.Wondering if a changecbass wrote:You'll want to use the full wave bridge capacito rinput.
Darin
				dcribbs1412
Thanks BobBob-I wrote:Glad to hear you got it. Yes, try the 220k. You could get crazy and calculate the voltage divider values, or you could swap the resistor and take a wag.dcribbs1412 wrote:Got it... I have 520V now but the bias went wild.Wondering if a changecbass wrote:You'll want to use the full wave bridge capacito rinput.
Darin
I'll try a 220k and see...I feel I'm getting closer
do I need a blocking cap?
thanks for your time
Darin
Bias taps
Darin, I knew I had this somewhere, it used to be available on the Torres site. This makes a good general reference for when you need a make bias suppy from the HT winding.
TM
						TM
				dcribbs1412
Re: Bias taps
Thanks TMToneMerc wrote:Darin, I knew I had this somewhere, it used to be available on the Torres site. This makes a good general reference for when you need a make bias suppy from the HT winding.
TM
much appreciated
Darin
