Degooping hard epoxy
sonicmojo
Post by sonicmojo »
Does anyone have a tip on doing this on a PCB with some epoxied components? I only need to remove about 1 inch worth. I have an adjustable heat gun but thought I would ask for tips first before attempting.
Bryan
husky
Re: Degooping hard epoxy
Post by husky »
sonicmojo wrote:Does anyone have a tip on doing this on a PCB with some epoxied components? I only need to remove about 1 inch worth. I have an adjustable heat gun but thought I would ask for tips first before attempting.
What amp is it?
Pretty difficult if it is potting epoxy designed for the purpose without destroying something.
______
John Suhr
www.suhr.com
sonicmojo
Post by sonicmojo »
It's actually a boutique effect pedal that I've been having a lot of screeching feedback issues with and wanted to maybe add a smoothing cap to it but unless I can see what I am dealing with, it is not really possible. It's not a big loss if I kill it but I was thinking since it is PCB and not point to point wiring, it may not be possible. Maybe I can add a 1500pf cap on the level pot instead. I hate goop.
Bryan
Kagliostro
Post by Kagliostro »
In my knowledge no way to remove epoxy without damage something
the only way I know is by mechanical action
a little burr in a Dremel or other sistems
Kagliostro
Dremel tool, very, very carefully. If you can clamp the Dremel in place and move the board instead of the other way round, you might find control is better.
9pins
Post by 9pins »
you could try that freeze spray stuff.
there is a right way to mic a musical saw
husky
Post by husky »
Heat and a dental pick works sometimes but assume you might destroy it in the process, usually better achieved with a small local heat gun like an Ungar used for shrink sleeve. I would advise asking the maker though, maybe he could tell you the best way to tweak it or make you a different version. Most people are eager top please their customers. What happens if you roll down your volume on the guitar to like 8 or 9? Most guys I know when using tube screamer type pedals never put the guitar on 10 and dont use a treble bleed for that. Also try a longer cable before you hit the pedal and not ultra low capacitance.
______
John Suhr
www.suhr.com
VacuumVoodoo
Post by VacuumVoodoo »
Aqua Regis (royal water) will dissolve epoxy but unfortunately also everything that's hiding under it.
Aleksander Niemand
affiliation:TUBEWONDER AMPS
Zagray!-review
sonicmojo
Post by sonicmojo »
John, thanks for the advice on the cables. I recently set up my pedalboard with some RG400 cables to the amp. I may experiment a little bit with a different return cable too. Thanks for the replies. I think I'm going to punt the idea and go back to a tubescreamer clone.
Bryan
VacuumVoodoo wrote:Aqua Regis (royal water) will dissolve epoxy but unfortunately also everything that's hiding under it.
Oh, yeah. I have some of that. :shock:
http://en.wikipedia.org/wiki/Aqua_regia
halfbackstrat
Post by halfbackstrat »
Epoxy resins should dissolve into Acetone?
It's an Organic Ketone and thus should be ok with the components, provided you don't get much on them.
Hope this helps.
Source: Chemistry Student
Matt
Omicron
Post by Omicron »
Acetone works on uncured epoxy resins. I've never seen acetone do anything to cured epoxy. This is from experience w/ fiberglass boat repairs.
The only way I've ever removed cured epoxy is physically, through sanding, grinding, etc.
PWE Amplification
Post by PWE Amplification »
If you look at the spec sheet for some encapsulating epoxies you'll see that acetone will indeed disolve it...after 30 days of submersion :lol:
Zippy
Post by Zippy »
PWE Amplification wrote:If you look at the spec sheet for some encapsulating epoxies you'll see that acetone will indeed disolve it...after 30 days of submersion :lol:
... as well as the circuit board. :lol:
FUCHSAUDIO
Post by FUCHSAUDIO »
I bought degooping liquid from one of the encapsulation/epoxy makers. It took about a month of soaking and dental picking to get past it. By the time i got to the parts, the values had come off and each part had to be measured. It's a tough process. You have to decide if it's worth it.
