Here's a gutshot, considering the existing layout and how many mods I've made, I think I did well keeping it organized. I certainly learned a TON from this amp and the X10 clone I did. Once I get my stuff to build the dummy load I will post scope shots.
You can see the shielded runs and the spot where my burned rail resistor roasted the turretboard a bit. I'm pissed about that, but hey chicks dig scars! I think there might be a metal shaving stuck under the mosfet because I had the chip loose, all was good. I tightened it down (w the white plastic insulator ring) and the R burnt (and that was all I did different). Then I loosened it, replaced the R and all is fine. So gotta look into that more because I do want to secure it better.
[img
