Thanks Structo and Luthierwnc for replay me, i have an experience to fix Tv, and i have build same kit , but i don't have experience in vacuum tube... so i konw the risk of hig voltage.
I have a good badget, for good amp i can spend max 1000 euro
I like metallica and AC/DC , my guitar is a Epiphone les paul, i play gutar at home usually 1 hour a day.
Hi Stefano , if your "sound model" is metallica or AC/DC , Dumble amp type is not for you! In my personal opinion. You can post in technical discussion , there are many guys can help you in your new project amp!
+1 on Sergio. Make a Marshall-style amp. Easier, cheaper and a lot fewer holes in the chassis. Angus plays (and I'm no expert but his rig doesn't change much) a model 1959. That's not the year, just the version. Here is site mostly devoted to those builds.
Even if a Dumble style amp (HRM) is perfectly capable to deliver high gain sounds, I think that you are in the "wrong" section
With 1000 euros you can find many good tube amps, used or new, that are more indicated to satisfy your needs...if you want to build something, look for a soldano slo clone...with 1000 euros you're in the budget...
