Liverpool EL84 cathode question
andrew
Post by andrew »
I am building a Liverpool and the schematic says to use one 120uf and one 120r for each pair of EL84s. All I have is one 62r and one 220uf to handle all four EL84s ( like the Rocket). Has ayone tried this? Thanks.
dartanion
Re: Liverpool EL84 cathode question
Post by dartanion »
You should be fine with the 62ohm and 220uF bypass cap. Make sure you have a beefy cathode resistor though, I use 10W or greater and usually wirewound.
JamesHealey
Post by JamesHealey »
should be fine like that, just make sure you've got a good high wattage quality resistor in place.
andrew
Post by andrew »
Thanks guys. Just wondering why are the 4 cathodes hooked together on the Rocket and on the Liverpool they are separated into pairs? Thanks again.
Andrew you better look at both layouts and or schematics again.
