octal preamp
andrew
octal
Post by andrew »
Thanks for the warning!
UR12
Re: octal preamp
Post by UR12 »
Johnhenry wrote: Sharp-cutoff pentode, Very good sounding amp Dana, you hook the 6SJ7 up as a pentode or a triode ?,
Yes, it's hooked up as a pentode
Johnhenry wrote:My experience with octal's are bout the same, some are microphonic, some not so much,
This is very true. I went through about 2 doz Used and NOS 6sj7s that were ALL microphonic to some extent. I fnally settled on a new Sovtek reproduction (Metal cas not glass). I am sure you will have the same problems with the new production tubes. It's a pain finding "the one" that works. Same thing with the 6sl7. If you keep the gain down on the new Sovteks they seem to work a little better so I would recomend a 6sl7 in say a Boogie or Soldano circuit :lol: These are great sounding tubes and they are very fun to play with and offer a distinct sound over the 9 pins
Johnhenry wrote:I do know this, set up right, octal's are very touch sensitive to the Guitar, I have a great collection of octal tube's, if you need some and I have the # I'll donate some for this thread, I have a very large old tube collection, and what's sad I still have to buy a few here and there, :D You just never got all ya need !
Can you ever have enough tubes? :lol: Most of the sensitivity in my experience has to do a lot with the way the tube is used and the circuit it is in.
macula56
Re: octal preamp
Post by macula56 »
hello UR12.
that's a great sounding amp. i want to experiment with parallel SE. any good diagrams to help get me started? is it as simple as it sounds to hook up? thanks. jmac
funkmeblue
Re: octal preamp
Post by funkmeblue »
check out http://www.angela.com/ under the how to section.....super single ended amp project
