Internal Dumbleator Question
Say if a fellow wanted to build a Dumbleator loop into his ODS style amp, then use the output pot of the loop as a master volume instead of the regular 1M master volume pot.
How would you configure that?
Would you place a fixed resistor in the place of the 1M Master?
If so, what value, like a 500K or 220K?
erwin_ve
Re: Internal Dumbleator Question
Post by erwin_ve »
Structo wrote:Say if a fellow wanted to build a Dumbleator loop into his ODS style amp, then use the output pot of the loop as a master volume instead of the regular 1M master volume pot.
Instead of the master I used a fixed voltage divider; 680K-330K.
And the output pot of the loop on the frontpanel.
So like this?
Did that give enough gain without overdriving the next stage?
heisthl
Post by heisthl »
My Fav values for MV sub are 270k/100k to ground for cleaner amps and 270k/220k when you want a dirtier amp - The concept of return as a master works really well.
www.RedPlateAmps.com
markusw
Post by markusw »
Do you guys include a bright cap with the fixed voltage divider ?
Peace,
Markus
heisthl
Post by heisthl »
Tried a few values, settled on 30p, actually like it better without any.
Thanks Henry, I was hoping you would pop in.
Could a person put a trimmer for the master then dial in the sweetness?
Or is that too much current?
markusw
Post by markusw »
heisthl wrote:Tried a few values, settled on 30p, actually like it better without any.
Cool! Thanks! 8)
heisthl
Post by heisthl »
Structo wrote:Thanks Henry, I was hoping you would pop in.
Trimmers work just fine... more junk to mess with :)
erwin_ve
Post by erwin_ve »
Structo wrote:So like this?
Yes like that. It's supposed to simulate at 30% taper pot half way up.
butwhatif
Post by butwhatif »
I like the straightforward concept of the classic master as we know it. I have a trimmer in the send and return, but have set the sweet spot for each, and pretty much leave them alone. As long as normal play mast volume is between 3-6, I'm happy. I like the thru sound of the loop with nothing plugged into it.
Luthierwnc
Post by Luthierwnc »
I'm going to take this slightly off topic but one school is that you need an outboard D'lator with medium capacitance (around 25 puffs per foot) send and return cables to take some of the highs off. Those units (if stock) have whopping bright caps.
If you are building one on-board, do your reduce or delete the bright caps according to how much capacitance you expect to lose in the cable runs? In the end, I'd just hardwire them by ear but I'd be interested in knowing if anyone has put more study into this,
Thanks, Skip
My D'lator is built to the schematic with the 0.001 bright on the drive and 270p on the recover out, and I'm using 3' cables to connect it to a low-plate classic. For a SC guitar the drive bright is way too much, but the rec out bright sounds very good. An acoustic-electric (Taylor w/ Expression system) likes exactly the opposite- drive bright on, rec out off, and in general this is a really great sounding acoustic rig.
Yeah, I don't really use the bright switches on the D'lator.
I have tried them of course and I agree with Martin that the .001 is mucho bright!
I wonder why he chose such a large bright cap.
I think I changed mine to 500pf.
