I'm following this community for quite a long time now, and I already really love you all
I already researched quite some information and now I get to the point where I want to buy the first parts... So here some questions to prevent me from doing something silly:
1) Resistors: I'd order 2W metalloxide resistors for all "standart" resistors. As I read they should have low noise and since the Trainwreck Express is a high gain amp I think this would make sense.
I have problems finding 3W 9k1 resistors, has anybody a clue where I can get those in Germany?
2) PT: I'd order this toroidal transformer: http://www.ampdesign.de/Trafo%20NT18.htm
It's been used in several TW clones I've seen and it seems to work fine.
Here one (probably dumb) question: What does "0-220-290V" exactly mean? I've read that like a 100 times but I've never seen a description...
3) OT: Hammond 1645 http://www.tube-town.net/ttstore/produc ... -1645.html
There is also an "easy wire" version of this, whats different?
4) Caps: for "higher" values Orange Drops, vor "lower" the Silver Micas, I can get them easily in my shop.
Are these electrolytic capacitor suitable or do I need some with higher quality? I've seen some ten times more expensive then these: http://www.tube-town.net/ttstore/produc ... axial.html
I'll build my amp based on Ceriatones layout and circiut. My electronic knowledge should be enough + after I've build this amp I hope I'll understand every part of it and then try to mod it. A friend of mine already built some amps so I'll also get som help there...
One more question: When you build an amp, what do you buy first? The electronical comppnents, the cassis, the PT and the OT? Where do you start your amp?
So many questions, but I hope somebody helps me
