For the neg feedback should I use the 4 ohm tap and alternate FB resistor value (Mine is a 50 watt amp)?
Progress report and comments:
I spent much time on my layout (you would think I might be building more than one of these hehe!
 )Layout seems to take longer than the actual build, but is paying off as I begin construction.
control panel laminates/templates are printed. The ink looks a bit faded, but Kinkos could not do any better. I wonder if doing them in color would help (even though the panels are black and white)
From 2 feet away, they look like the real thing.
Boards are drilled with eyelets installed. (I used Mouser 534-45 eyelets but next time I will use smaller eyelets (Mouser 534-35) except where needed.)
Precison PS board is 95% populated (waiting on back ordered parts)
Relay board is complete and tested (I did this the hard way, but it is really slick. Will post a pic sometime)
Chassis is partially drilled (warning - cheap Harbor Freight drill press has some play in the vertical control which can cause the bit to wander if you are not careful!
 )Heard a negative comment about the step bits from Harbor Freight. Mine works OK, but then again I am working with Aluminum only.
Debating whether to buy a table saw and build my own cab. I want the amp to have a pro look with Tolex. I plan on gigging with this amp.
whit
