25 Watt Plexi with EL-34's???
rp
Re: 25 Watt Plexi with EL-34's???
Post by rp »
To the OP: you need to know what you want before you have a build made. A Plexi with 6V6s at 370-400V will still be plenty loud.
10thTx
Post by 10thTx »
This will get around 23 watts & the switches allow some versatile tone options. The paralleled V1 adds about 30% gain with no increase in noise.
With respect, 10thtx
Andy Le Blanc
Post by Andy Le Blanc »
theres also a 6cm6 ... its a 6aq5 in a 9 pin envelope
from there your into 7 pin tv and radio types, but theres several 7 pin beam tubes
the plate v becomes quite low and so does the driving voltage
its the size of the envelope that limits the heat dissipation
theres a 6cz5 its a 9 pin that'll take 350v but has 10w dissipation
Id try a deluxe opt, and a blues jr or princeton/champ pt... only rated to 70ma
even a low watt rig can be damn loud with an efficient speaker
lazymaryamps
rdamato
Post by rdamato »
rp wrote:To the OP: you need to know what you want before you have a build made. A Plexi with 6V6s at 370-400V will still be plenty loud.
Good Point. A 22 Watt amp would be perfect for my needs. I do not like a compressed tone ala' an 18 Watt/ EL-84 based amp. I prefer the more open Plexi sound.
rdamato
Post by rdamato »
TTT
John_P_WI
Post by John_P_WI »
IMHO, Get a proper built "50" watt plexi, built with proper transformers and tubes with Power Scaling.
If you are here in North America, check out youtube for these North American manufacturers who have an amp similar to this:
www.soultoneamps.com
www.suhrguitars.com
The badger is offered in 18 and 30 watts, check out Pete Thorn's vid of the badger......
http://www.youtube.com/watch?v=V5N88mHMBW0
www.reinhardtamps.com
or Rockytop amps
www.youtube.com/watch?v=Lg6m0n115Ms
or any of the pro builders here who use Power Scaling or VVR.
10thTx
Post by 10thTx »
"Proper" amp and trannies? :?
The Badger 30 looks like a very nice amp for $2345. Looks to be an EL34 version of an 18watt. (per Suhr website)
I think this Texas Raptor I scratch built came in complete under $600 including cab and speaker using Hammond trannies.
http://s28.photobucket.com/albums/c216/ ... itarII.jpg
I think they are numerous ways to go to get a great sounding Plexi-ish amp that is in that 25-30watt range. There have been quite a few good suggestions made that are worth considering that might meet that need.
Wow!
Pretty amp and guitar! :D
Me likey! :D
[IMG:576:432]http://i28.photobucket.com/albums/c216/ ... itarII.jpg[/img]
10thTx
Post by 10thTx »
Guitar was built by my son who is a much better luthier & wood worker than I am.
with respect, 10thtx
Tone Lover
Post by Tone Lover »
Both are very nice your son is a woodworker to be proud of but I have seen several of your amps and I think he takes after his father.
Bill
Lonely Raven
Post by Lonely Raven »
Structo wrote:Wow!
Me likey! :D
Wow, that is a beaut! I'm thinking about building my replacement Magnatone cabinet in hard wood...and I think that photo just game me an idea!
Jack of all Trades,
Master of None
cxx
el34 low volt plexi
Post by cxx »
Sorry to revive this thread but I was just what I was looking for.
I built a plexi clone on the remains of a crate vc3112. Used the 68 plexi schematic with the crate hardware and transformers. These were the Chicago transformers that were from magnetic components. The 4k output transformer seemed a reasonable match to the 2 el34s. The power transformer provided about 340 volts on the plates. I just modified the dropping resistors to maintain enough voltage on the preamp and phase inverter.
I tried it with 6v6, 6l6 and the el34. The el34s really sound best in this circuit, especially when played on the clean side. I've tried the JJ 6v6's in the full scale plexi but really preferred the el34s in that one also.
