rocket noOb
fretless
Re: rocket noOb
Post by fretless »
sliberty wrote: Yes, that should be OK. Certainly better than nothing.
ok cool , easy fix , Thanks !
fishy
Re: rocket noOb
Post by fishy »
dansamp wrote:
fishy wrote:That looks like a nice build. Killer cab to boot.
RJ's chassis and board by the looks of it. I am sure it sounds as good as it looks.
I would draw your attention to the power tubes cathode setup. The cap is seated directly over the resistor which is not ideal. It might be well spaced off the resistor but it is hard to tell. You might want to consider moving it to one side which will reduce the heat load on the capacitor and likely prolong its life.
Check the layout in the files section if it is not clear.
that is my build
the cap is spaced above the resistor but when the chassis is upright it is under the resistor while the resistor in turn is mounted against the
chassis
I figured heat rises so it would go up into the chassis and away
from the cap
right ???
Dan. :roll:
No offense meant here. Thats a great build as I said.
dansamp
Re: rocket noOb
Post by dansamp »
none taken,
but I did give this location a bit of thought :D
fretless
Re: rocket noOb
Post by fretless »
here is the cap in question
[IMG:768:1024]http://img.photobucket.com/albums/v735/ ... et/cap.jpg[/img]
I managed a few grommets , turns out wasn't all that easy
[IMG:1024:768]http://img.photobucket.com/albums/v735/ ... ommets.jpg[/img]
and I labeled the back what do you think ?
[IMG:1024:768]http://img.photobucket.com/albums/v735/ ... t/back.jpg[/img]
so I ran into something unsual , maybe you guys can take a guess as to what's up . The jack it's in here is loud and clear , but the jack next to it is almost no output and kinda fuzzy when turned up . What do you think ?
[IMG:1024:768]http://img.photobucket.com/albums/v735/ ... kerout.jpg[/img]
dansamp
Re: rocket noOb
Post by dansamp »
do not use the second jack unless you are using the first jack
the first jack is a shorting jack the second jack is non shorting
fretless
Re: rocket noOb
Post by fretless »
dansamp wrote:do not use the second jack unless you are using the first jack
Thanks Dan , good to know ! Cheers
amplifiednation
Re: rocket noOb
Post by amplifiednation »
That cab is sick
Amplified Nation
www.amplifiednation.com
@ampnation
Re: rocket noOb
Kinda looks like my Distortions cab 8)
Lonely Raven
Re: rocket noOb
Post by Lonely Raven »
I so wish I could find wood like that....
Jack of all Trades,
Master of None
Bob S
Re: rocket noOb
Post by Bob S »
Hey Mark - please stop posting pics of that cab. :lol:
I'll spend the rest of today walking around with a boner & my tongue hanging out...
Why Aye Man
Tone Lover
Re: rocket noOb
Post by Tone Lover »
and I thought I was the only one that got a boner lookin at that cab
selloutrr
Re: rocket noOb
Post by selloutrr »
I have a vintage dymo label gun and red tape if you want the TW correct rear labels in "Red Rocket".
PM me
My Daughter Build Stone Henge
ampmike
Post by ampmike »
Mark that cab is a stunner!!!Im working on a maple today.I hope 2 number 10 biscuits per 45 corner is enough.What I really like to know is how to get a finish like that.My wood does not have anywhere near that figure.NICE!!!Mikey
fretless
Re: rocket noOb
Post by fretless »
M Fowler wrote:Kinda looks like my Distortions cab 8)
That is a stunning piece of work !
fretless
Re: rocket noOb
Post by fretless »
it does look like your work , the way the front tapers down to the controls and the corner seam , though Dan said it was " Larry Mann aka Distortion" , hmm...
