Piher, Beyschlag Resistors
- David Root
Recently I bought some 68K Piher 1W from an EBay guy in Italy for my 183 type build. Haven't tried one yet but they look kosher.
This morning I got an e-mail from him offering a huge list of these resistors along with a few Iskra, see below. I know HAD used Piher & Beyschlag in some of his builds and they are de rigeur in vintage correct Marshalls. There are lots of Dumbley values here.
Which Dumbles did HAD use these in? And would they possibly add anything to a 183 build in spots other than that 68K 1W?
RESISTORS FOR SALE
1/2 and 1/3W 0,50$ each
51R 51 ohm Piher
330R 330 ohm Piher
470R 470 ohm Iskra 1/3W
820R 820 ohm Piher 1/3W (in typical Marshall circuit is placed on 12AX7 ECC83 cathode, here 1/3W can be used because there is a very little current, like 0,01W...)
3.9K 3K9 Piher
12K Piher
18K Piher
20K Beyschlag
39K Piher
820K Piher
1M2 1,2M Piher
1M8 1,8M Piher
2M2 2.2M Piher
2M7 2,7M Piher
4M7 4,7M Piher
1/2 and 1/3W PIHER 0,80$ each
470R 470 ohm
820R 820 ohm
910R 910 ohm
1K
2,2K 2K2
2,7K 2K7 Piher 1/3W (in typical Marshall circuit is placed on 12AX7 ECC83 cathode, here 1/3W can be used because there is a very little current, like 0,01W...)
5,6K 5K6 Piher 1/3W (in typical Marshall circuit is placed on EL34 as grid stoppers, here 1/3W can be used because there is a very little current...)
6.8K 6K8
8,2K 8K2
10K
22K
27K
33K
47K
56K
68K 1/3W (in typical guitar amp circuit is placed on 12AX7 ECC83 grid input, here 1/3W can be used because there is almost NO CURRENT...)
82K
91K
100K
120K
150K
180K
330K
470K
680K
1M
1/2W 4$ each
5,6K Iskra
220K Piher
0,8W Beyschlag 0,50$ each
18K
33K
56K
82K
390K
560K
1M
1W and 2W 0,30$ each
1,2 Ohm Piher 1W
22 Ohm Iskra 1W 10%
22 R Allen Bradley 1W JAN 10%(selected for 5% tolerance)
150R 2W Beyschlag
82K 1W (presumably Draloric)
270K 1W (presumably Draloric)
330K 2W (presumably Draloric)
1W 0,60$ each
1,5K 1K5 1,5 K Piher 1W 10% (selected for 5% tolerance)
1,5K 1K5 1,5 K Iskra 1W 10% (selected for 5% tolerance)
1,8K 1K8 1,8 K Piher 1W
6,8K 6K8 6,8 K Piher 1W
180K 180 K Beyschlag 1W
560K Beyschlag 1W
1M2 1,2M Iskra 1W
1M5 1,5 M Iskra 1W
1W 0,80$ each
470 R Beyschlag 1W
820 R Allen Bradley JAN 1W
820 R Piher 1W 10% (selected for 5% tolerance)
1K 1 K Piher 1W
10K Beyschlag 1W
33K Beyschlag 1W
47K Beyschlag 1W
56K Beyschlag 1W
82K Piher 1W
150K Beyschlag 1W
180K Piher 1W
270K Beyschlag 1W
470K Iskra 1W
560K Piher 1W
560K Iskra 1W
680K Piher 1W
680K Iskra 1W
1W 2$ each
10K Piher
150K Piher
270K Piher 10% (hand selected for 5%)
1W 3$ each
5,6K Piher
33K Piher
1W 4$ each
68K Piher
68K Iskra
2W 4$ each
100K Iskra
CAPACITORS
Mustard 27nF 400V vertical mount, 2,5$ each
Ducati/Microfarad MLT 400V 10% Axial: 22nF and 10 nF 0,50$ each
Ducati/Microfarad MLT 160V 10% Axial: 47nF. 22nF,18 nF,15nF,10nF 0,30$ each
ERO Roederstein MKP 1830 33nF 100V 5c each
ERO Roederstein MKP 1830 68nF 100V 5c each
SHIPPING PRICES REGISTERED MAIL FOR US and EUROPE
12$ up to 50 gr
14$ up to 100 grams
18$ up to 250 grams
22$ up to 350 grams
RESISTORS FOR SALE
51R 51 ohm Piher
330R 330 ohm Piher
3.9K 3K9 Piher
12K Piher
18K Piher
20K Beyschlag
39K Piher
820K Piher
1M2 1,2M Piher
1M8 1,8M Piher
2M2 2.2M Piher
2M7 2,7M Piher
4M7 4,7M Piher
470R 470 ohm
820R 820 ohm
910R 910 ohm
1K
2,2K 2K2
6.8K 6K8
8,2K 8K2
10K
22K
27K
33K
47K
56K
82K
91K
100K
120K
150K
180K
330K
470K
680K
1M
1/2W 4$ each
5,6K Iskra
220K Piher
18K
33K
56K
82K
390K
560K
1M
1,2 Ohm Piher 1W
22 Ohm Iskra 1W 10%
150R 2W Beyschlag
1W 0,60$ each
560K Beyschlag 1W
1M2 1,2M Iskra 1W
1M5 1,5 M Iskra 1W
1W 0,80$ each
470 R Beyschlag 1W
1K 1 K Piher 1W
10K Beyschlag 1W
33K Beyschlag 1W
47K Beyschlag 1W
56K Beyschlag 1W
82K Piher 1W
150K Beyschlag 1W
180K Piher 1W
270K Beyschlag 1W
470K Iskra 1W
560K Piher 1W
560K Iskra 1W
680K Piher 1W
680K Iskra 1W
1W 2$ each
10K Piher
150K Piher
1W 3$ each
5,6K Piher
33K Piher
1W 4$ each
68K Piher
68K Iskra
2W 4$ each
100K Iskra
CAPACITORS
12$ up to 50 gr
14$ up to 100 grams
18$ up to 250 grams
22$ up to 350 grams
Re: Piher, Beyschlag Resistors
From what I've seen most 2nd and 3rd Gen's have Piher as the carbon film type, the early version (fat body-pre 69') 2% 1/2 watt type and 2W. Occasionally he sneeked in a Piher 3W (#40 NFB comes to mind)as well. The early version 2% 1/2W Pihers are the most cherished and it's found in early Marshalls as well. I've seen very few red Beyschlags in Dumbles.
FYI, it's 2W Piher on #183's V2 grid.
FWIW, the Dumble Beyschlags to have are the Sprague Q lines.
If I ge a chance tonight I will post pics of the different versions of Piher and Beyschlags from 1/4W through 3W.
Mike
Mike
- David Root
Thanx Tonemerc. I thought the 68K on V2 of #183 was 1W, not 2W. But I see you are right. Well, 1W is better than 1/2W.
So I have no idea how old these Pihers are. Are there significant tonal differences or is it more a matter of being period correct?
Here is a pic of the 68K 1W Pihers I got from this guy. They are 1/4" diameter, 5/8" long and each lead is 1 1/4" long.
Nice!
Wouldn't it be wonderful to have a huge toy box full of every type and brand of vintage components?
It seems the more digital we get, the fewer parts that are being made that actually take audio into consideration for their design.
- David Root
All new passive parts for audio seem to be for the hi fi crowd. That's because they're not skinflints like most MI amp folks seem to be. I wish there were more exceptions like Sozo around, for instance.
You can still get nearly all the old parts, just takes a wad of $$$. The incidence of unobtainum increases each year though.
Here's a few vintage parts
Caps: Phillips Mustards, Radiospares & Lemco silver mica, Lemco ceramics
Mallory PVCs and various Sprague 220, 225 & 6PS
Resistors: Piher, mostly red a few tan Beyschlag and a few Iskras
Piher: .25W, .5W, 1W&2W and an older 2W & 3W.
Beyschlag: tan .5w, beige .7W and 1W
Vintage parts for a transitional Blackflag JTM50: Mustards, Piher, Morganite CC, Hunts, Erie & Phillips caps
Lee fuse holder, Bulgin Mains connector
It needs about 6 Iskras for it to be correct, but I'm using all Pihers as I refuse to pay the. price for period correct Iskras.
TM
TM
David that's a gloss finish smaller body 2W, the 68k in #183 and the one I used is the matte finish smaller 2W. Pihers can be tricky to identify as they can have different body sizes and finish gloss. I have Piher .5's with three different body sizes. Also, red Beyschlags are commonly confused as Pihers.David Root wrote:Thanx Tonemerc. I thought the 68K on V2 of #183 was 1W, not 2W. But I see you are right. Well, 1W is better than 1/2W.
TM
i drooled on my keyboard.............ToneMerc wrote:Here's a few vintage parts
TM
- David Root
Tonemerc, that's interesting as they were sold to me as 1W. Is there any tonal difference? Probably nothing significant?
Nice resistor porn, I like the ISKRA the best in the bunch hard to find now.
Thank you David.
Thank you David.
