Can anyone tell me what brand wire this is?
- Lonely Raven
It's 20AWG Stranded Copper and says:
CSA LL89093 TEW
And it's a pretty sparkly blue/violet
[img:500:300]http://lonelyraven.zenfolio.com/img/v22 ... 2112-5.jpg[/img]
CSA LL89093 TEW
Jack of all Trades,
Master of None
Master of None
Re: Can anyone tell me what brand wire this is?
No, but here's a possibility:
http://www.nationalwire.com/product_spe ... uctsID=126
Agency Voltage Rating: 600 Volts
Factory Spark-Test Voltage: 8000 VAC. 100% of all wire is tested at this voltage.
Insulation Breakdown Voltage: > 11000 volts, peak.
IR: Insulation Resistance, wet: > 2900 megohm/100 mtr, metal to water bath at +20ºC
Nominal Dielectric Constant value: 4
Flame Properties: Self extinguishing. Meets UL VW-1
Fungus: Fungus resistant
- Lonely Raven
Interesting...thank you for that!
It seems this type of wiring is basically used for panel wiring, HVAC, typical contractor stuff it seems.
Jack of all Trades,
Master of None
Master of None
My Daughter Build Stone Henge
- Lonely Raven
So that explains the printing on the wire, but doesn't help me get closer to finding this wire specifically. At least I know what it is and I can get something similar. Thanks for the info thus far!
Jack of all Trades,
Master of None
Master of None
CSA is the certification for the wire. TEW is the type of wire. I got to the link I posted by searching for "TEW wire." Give it a try and you'll see.
- Lonely Raven
I did, many times. I was hoping one of the numbers would lead me to a specific brand of wire. But it's probably just one brand out of thousands with similar ratings and certification.Phil_S wrote:CSA is the certification for the wire. TEW is the type of wire. I got to the link I posted by searching for "TEW wire." Give it a try and you'll see.
Jack of all Trades,
Master of None
Master of None
how many strands of wire?
tinned or bare copper?
what gauge is the wire?
These questions will help a lot in tracking down a make / model out of thousands of options.
- Lonely Raven
Understood. I'll look into when I next have the amp over. Thanks!selloutrr wrote:how many strands of wire?
Jack of all Trades,
Master of None
Master of None
