Best Neutral RTV Goop?
David Root
Post by David Root »
What do you all use? I need something to hold some heavy caps in place.
FUCHSAUDIO
Re: Best Neutral RTV Goop?
Post by FUCHSAUDIO »
GE Silicon sealer and household glue is excellent. Home Depot has it in clear or white. I also use (don't laugh) Liquid Nails. They sell a toothpaste sized tube of clear Liquid Nails that is seriously strong shit.
David Root
Thank you very much! I take it the Liquid Nails should not touch anything but the caps?
FUCHSAUDIO
Unless you want it to hold down other things....
amplifiednation
Post by amplifiednation »
hahaha, well put.
Liquid nails will hold wood to a concrete floor...forever.
Amplified Nation
www.amplifiednation.com
@ampnation
If you use caulking be sure it doesn't contain acetic acid.
David Root
Tom that's why I put the word "neutral", meaning not acidic, in my subject line. I did read that thread, pretty scary stuff.
FUCHSAUDIO
Also avoid latex based, as it does have water/moisture content that can migrate. The current GE silicones (The one I have here is labeled Premium Waterproof Silicone window, door, attic, basement) is pretty goods, no outgassing and holds things solid.
John_P_WI
Post by John_P_WI »
David,
I work for a very high tech company, may I suggest Momentive Adhesive (Formerly GE) RTV 5818 which we use it for all of our pcb applications.
http://www.mgchemicals.com/products/5818.html
It's not cheap though...
Zippy
Post by Zippy »
John_P_WI wrote:I work for a very high tech company...
Hey John,
I'm familiar with "high tech" - I might even work for one myself. :roll:
What makes a company "very high tech"? :?
John_P_WI
Post by John_P_WI »
Ha good one Zippy, you got me on semantics here.
How about an industry leading medical diagnostic equipment company? At least it sounds "very" high tech.... :roll:
rdjones
Post by rdjones »
On a recent rebuild I used black automotive weatherstripping adhesive.
rd
David Root
John, that is an interesting spec on that 5818. Marine grade, even. In a 300ml container I'm afraid that most of it would set up before I used it all.
At $17 in Canada that is 8x any caulk I've used before, but to be fair that was el cheepo bathroom caulk.
If I could get something close in a smaller tube that would be better.
Gaz
Post by Gaz »
Structo wrote:If you use caulking be sure it doesn't contain acetic acid.
Crap. I've been using DAP 100% Silicone that 'has' acetic acid, or gives it off as it cures. I just assumed it was okay because it was 100%. Looks like the stuff Fuch recommend has it too though...
Gaz
Post by Gaz »
More specifically, I've been using a dollop on the bottom of radial electrolytics to secure them down to a garolite turret board. Does anyone think the silicone touching the leads will actually corrode them?
