However, it turns out that neither were the cause.
Here's whats going on so far:
When the amplifier is turned up past 4 on the reverb channel, the amplifier breaks into a horrible parasitic oscillation which causes distortion and a crackling/sputtering sound to the notes.
Turning the Reverb past 5 and knocking the tank causes a bad oscillation at about 5khz or so.
I've been through it with my gen and scope for the past week and can't figure it out!!
Here's what's been tried so far:
The obligitory changing tubes. I tested and changed out ALL of the tubes with known good tubes from my collection and that didn't help anything.
I've tried replacing the filter cap that feeds the preamp nodes.
I tried replacing the plate resistors for the mixer stage.
I tried replacing the cathode bypass cap for the mixer stage.
The amp does this with the reverb driver tube pulled, and the reverb recovery jack shorted or unshorted.
The power section seems to check out okay, tubes are biased properly, and I can inject a signal right at the input cap to the phase inverter and get full output very clean into a load or speaker and on the scope.
The problem seems to be coming from either the recovery mixer or the trem section. If I inject a signal on either side of the mixer (v4) it gives the same results that plugging a guitar in and playing does- nasty sputtering oscillating sound. I've re-flowed almost all the joints on the board, re-tensioned all the tube sockets...checked numerous resistors...
I am pulling my hair out! Any advice guys?
