[quote="pula58"]fiddling around with an Emi Deltalite II 2512, compared to JBl E120...
http://www.youtube.com/watch?v=Mj4ws4JSZzo
Anyone compared the Emi Delta Pro to the neo Emi Deltalite?
Re: Anyone compared the Emi Delta Pro to the neo Emi Deltalite?
I never liked the beam blocker effect, and have tried it w/several speakers thru the years. I think it screws w/the phase of things coming out of the cab. While it might work in one situation, many others fail. I would much rather aim/tilt the cab into the right area of the room that makes it work. That seems to make for a wider area to hear things as they are.
I just received a 10" Delta Lite for my mini HRM combo, it only weighs about 4lbs!
I played my 50w through it a little and it sounds pretty good, but definitely needs a whole lot of loosening up, so far as I can tell.
It has hi-fi type screw connectors, does anyone suggest keeping them or going for a solder join to the screw?
Rog
Rog
When I tried the Tonkerlites it didn't seem like they had any bottom end.
How is the bass in the Delta lites?
KappaLite?
Hmmm...just did some curve overlapping with the published specs of EVM, DeltaLite and KappaLite. It almost looks like the KappaLite is closer to the EVM. Anyone tried it?
The thick jagged line is the EV, the reddish line is the DeltaLite, and the darker thin line is the KappaLite. The scales had to be stretched and changed to correctly compare the specs while protecting the innocent (me).
-g
