Looking for a LTP PI>pair of KT88 schem.
fusionbear
Post by fusionbear »
Hello again. I want to build another clean amp. This time I want to build a simple fender style tone stack into a LTP PI into a pair of KT88's
Any body have a power amp schematic they could share?
I'm thinking of using a M style power transformer with about +480 at the plates.
12AX7a>tonestack>12AX7b>12AT7 PI> 2- KT88's
I am assuming the 12AT7 will drive the KT88's better?
Learning to learn...
soma_hero
Re: Looking for a LTP PI>pair of KT88 schem.
Post by soma_hero »
Sunn 200S. The only thing that matches your description is the 2xKT88 output.
Two triode stage, pentode stage driving triode concertina.
Great sound, and interesting design.
Roe
Post by Roe »
standard values work fine but decrease the 220k bias splitters to 150k or even a little lower.
If you want the 12at7 to really drive the kt88s try 47k plate resistors and a 270k cathode resistor ala BF fender. it will sound punchy but less compressed
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
fusionbear
Thanks guys!
I was aware of the Sunn, but didn't want to get that complex.
soma_hero
Post by soma_hero »
The Sunn only has 2 preamp tubes since it uses a single package triode/pentode. Pretty simple, but yes very different then usual.
fusionbear
soma_hero wrote:The Sunn only has 2 preamp tubes since it uses a single package triode/pentode. Pretty simple, but yes very different then usual.
My Weber Sunn clone of the S100 is similar:
5751a>gain stage>5751b> Marshall type plate fed tonestack>EF86 Recovery and driver>12AU7 PI in Cathodyne config.> 2- KT88's
I like it a lot, but want to experiment with a Fender type tonestack
Ian444
Post by Ian444 »
What's the expected grid bias voltage for KT88's, is it much more than for EL34? If it isn't much more, than any LTP schem for 4 x EL34 should be close. Another scheme is the Marshall Major with a cathodyne feeding seperate drivers, that will have no trouble driving KT88.
bb5000
Post by bb5000 »
Running KT88's at 660-670 Vp, 40 mA cathode current with -70 VDC at the grid.
