Taming the Bass
CHIP
Re: Taming the Bass
Post by CHIP »
I recently received 3 CTS 300k pots, found one to be 312k :D , so today I changed the bass pot in my #183. It did the trick, the bass is alot more managable. Instead of keeping the pot at 9 o'clock and lower I'm able to put it around noon, with good results.
Also finally wired the R/J switch correctly.
A great amp!
stelligan
Re: Taming the Bass
Post by stelligan »
CHIP wrote:I recently received 3 CTS 300k pots, found one to be 312k :D , so today I changed the bass pot in my #183. It did the trick, the bass is alot more managable. Instead of keeping the pot at 9 o'clock and lower I'm able to put it around noon, with good results.
A great amp!
I am having issues with my r/j switch as well. Is it on/on or on/off/on? And how did you wire the center lugs? I was just looking at your build thread and I am baffled with how that switch is operating..... Maybe you can PM me Chip?
Sorry for the derail.
Re: Taming the Bass
If you wired the on/off/on switch just as it is shown on the ODS amp (doesn't matter which one) the center position is just PAB.
It just puts that option on the front panel and does not affect the switch in Rock or Jazz.
I have that switch on my amp as well.
Re: Taming the Bass
A great amp!
I may have to give that a try if I end up hating the mid cap.
I'm thinking a .02 may be better.
Something else you can do is use a lower V1a bypass cap such as a 1uf or .68uf.
Then put the 5uf cap you pulled out on a switch and switch that in parallel with the lower cap, then the total will be the two values combined.
Gives you a single coil and humbucker option.
stelligan
Re: Taming the Bass
Post by stelligan »
Structo wrote:If you wired the on/off/on switch just as it is shown on the ODS amp (doesn't matter which one) the center position is just PAB.
Thanks Tom. I'm lame - that explains why the PAB on the back panel wasn't behaving as I expected.
talbany
Re: Taming the Bass
Post by talbany »
This is why 124's switch on the back was disconnected (ground wire).. when it was upgraded a on off on switch was added so no need for the back panel switch
angelodp
Re: Taming the Bass
Post by angelodp »
Tony[/quote]
Tony, thats a nice bit of amp archeology, perhaps it could be noted on the layout.
Best Ange
ChrisM
Re: Taming the Bass
Post by ChrisM »
angelodp wrote:This is why 124's switch on the back was disconnected (ground wire).. when it was upgraded a on off on switch was added so no need for the back panel switch
Best Ange[/quote]
Yep
It took me a bit of time to figure out why the PAB switch on the back did nothing when I built mine a few years back.
talbany
Re: Taming the Bass
Post by talbany »
Best Ange
i will do that
T
stelligan
Re: Taming the Bass
Post by stelligan »
Thanks Tony. Also is Jazz mode WAY quieter than Rock?
Dr d
Re: Taming the Bass
Post by Dr d »
Yeh, I also find the Jazz position much quieter!! I am sure thats normal.
Re: Taming the Bass
Yes it is on mine as well.
Less bass and gain.
Re: Taming the Bass
I'm liking a .02uf mid cap.
CHIP
Re: Taming the Bass
Post by CHIP »
Structo wrote:Yes it is on mine as well.
Less bass and gain.
Mine also.
gary sanders
Re: Taming the Bass
Post by gary sanders »
Structo wrote:I'm liking a .02uf mid cap.
changed my .01 to .05,a little much and was thinkin an .02 or .033 would do it
