hello to all, i have great contribution to this thread !
thanks to the mats great thread (and playing too
 ), last two weeks i spent some time to construct a little PP amp which have similar topology like mats, but unfortunately i finished with an PP amp notr S.E:
i tried to build something like this:
(ECC83->duble TS-> ECC83-> some penthode for OD-> and in output some tube like EL84 S.E)
i started good with ECC83 and dumble TS, but didnt have EF86 penthodes, nor EL84, but i had about 1000 TV tubes at home
, and i found small PP 15W OT in basement.. so i picked two PCL86 (  14GW8 i think in the USA) because penthode section in this tube is somelike smaller version of EL84, and triode section is like one half of ECC83..
two PCL's for phase splitter and PP output (datasheet says that will 12-14W came out)
penthode in OD is also picked from old TV , EF89 and EF80 were candidates, because i had them ( scattered everywere
finished an amp, clean channel with ECC83 and dumble TS was standard great, soft and rounded, but for OD i didnt have idea what to expect. but i must say,
those EF80 tube is excellent!! for soft, rounded, rocky distortion, without treble spikes in distortion! just big balls with LP in those sound (OD trimmer can go to max)
EF89 is not for use in this type of amp, because its bias (0->-40V), and this tube have something weaker , in the lifeless meaning, drive..
sorry for my bad english, and greetings from croatia!
