As in, lowering the bypass cap, lowering coupler value, etc?
Combination of the two?
I can't have my bass pot up above 9:00 before it is too much.
The mid is just about as bad.
I guess I would like to have more range in the control rather than all of it in the first quarter or half rotation.
Mainly in OD mode, the bass seems to lose definition down low.
I set the OD trimmer at 26K to ground with amp on.
I also need to filter just a bit of fizzie content off of the top in OD.
I tried larger snubber caps on V2 and didn't like that when they got too big at 500pf.
I backed those down to 390pf.
Then I tried a .02uf cap at V1b. That seemed to almost disable the bass pot so that went back to .047uf.
Then I tried a 1uF bypass cap on CL2, that seemed pretty good and is where it's at right now.
I also have a Ayan treble bleeder on the OD volume but it is set where it isn't doing much at all right now.
I was just curious if you guys had a standard approach to this?
Like, too much bass, lower bypass cap.
Or, too much bass lower coupling cap.
Or am I simplifying it too much?
Would it be as simple as installing a 250K bass pot?
