Ok thanks..talbany wrote:r..Don't mean to sound like a jerk!
Hope this Helps!!
....btw, you never sound like a jerk.
Hope this Helps!!
 ), then they're also going to take extra measures to tune the amp right before they sell it. Their belief was in their wire, the truth was in their effort.
 ...which would tend to point to a skin effect. Why else would surface area matter?talbany wrote:HiFi and audio engineers have been debating the differences in sonic quality between these two types of wires for years..Ken Fisher being one of them Many point out that braid-stranded wire is preferable due to its increased surface area...
...which would enhance any skin effect, as silver is a better conductor than copper.talbany wrote:.. I can't give away all my work I will say try to get it solid silver plated copper...
Which engineering community would that be? There are many.Aurora wrote:In the engineering community, there is an overwhelming consensus that skin effects are non existent at audio frequencies.
Electronically speaking, higher frequencies tend to travel on the OUTSIDE of the wire. It's called "skin effect." Tesla demonstrated this at a world's fair way back when by hooking himself up to high frequency, much to the shock and awe of the crowd. If I recall correctly, his hair was standing up and his body had somewhat of a coronal glow of sorts. Anyway, that's part of the explanation for why microwave-frequency devices use waveguides and not traditional conductors. At audio frequencies, I don't think it really makes a difference. I have used solid "hookup" wire quite a bit and the amps sound fine. welding cable is stranded for the flexibility, otherwise a solid strand would be just fine.wescaster wrote:I have rocket scientist friend helping me with my amp build.. Really he used to work for NASA, but he is a little cynical about musicians and tube amps.
He says there is no reason for cloth covered solid strand wire. He thinks stranded wire is best in all applications.
What is the advantage of solid wire?
