Reverb tank for vibroverb
grtamp
Post by grtamp »
Hi , which tank model for vibroverb is more appropriate?
Firestorm
Re: Reverb tank for vibroverb
Post by Firestorm »
grtamp wrote:Hi , which tank model for vibroverb is more appropriate?
Same as any Fender: 4AB3C1B. Four spring, 8-ohm input, 2250-ohm output, long decay, insulated input/grounded output, no spring lock, horizontal mount w/ open side down.
If you are not building the traditional combo and need to mount it in another orientation, Gibbs/Accutronics has a numbering system that assures you will get the correct tank for whatever orientation you will use. Check their website.
grtamp
Post by grtamp »
Thanks all for the helps!!
bye!
