Hi again Jeff,10thTx wrote:Is this getting closer?
with respect, 10thtx
I think Your schem around the EF86 is not like in the picture I posted.
Other things:
V1 coupling cap is 2n2.
Mid boost cap is 380p.
No mid pot, just 120k to ground after the .01.
PAB resistors not 22M but 20M.
Treble pot is 250kL.
Pre volume is a trimmer inside the chassis on my build.
The EH86 entrance 60p/470k (schem has 60p/470p).
After the 60p/470k there is 250p in to 470k to ground.
Also after the 60p/470k is drive pot (250kA). The signal goes to the viper while other side goes to ground and other side goes to the 1M/150k junction.
66n to ground on EF86 pin 1.
No 220k from point C.
No 220k from the OD master viper - straight to the switch.
From OD master viper there is 470p into 1MB (smooth pot). Other side goes trough 4n7 to ground. Smooth pot viper goes to side of the OD master pot (not on the ground side). This is quite like on Your schem but wired a bit differently.
Also I have a standby switch after the bridge rectifier.
Check the EF86 connections and I think we are pretty close of the same thing
