Hi,
Has any of you had a chance to look under the hood of this amp? From the manual I take that both channels have 3 gain stages, the lead channel has the option of adding a 4th gain stage for a boost.
Since all the Fryette/VHT amps have a cathodyne PI I would expect the same here.
Power amp is 4 cathode biased EL84 tubes. Does it have negative feedback? The absence of presence and depth controls suggest it does not.
Any input would be greatly appreciated.
Thanks and kind regards,
Stephan
Fryette Memphis
