Any suggestions welcome - I trolled around on the net and ended up more confused than normal.
Thanks in advance,
Bob
surfsup wrote:Software:
http://reaper.fm/
Hardware:
Presonus Firebox
If you want to start recording amp cabs, well you need mics, mic stands, mic cords, placement issues, room soundboards/treatment, etc.
I home record when I have time and record guitar direct in (plug the guitar into the hardware input). Then I use a "reamp" to send that signal as many times/"takes" as I want to an amp, and can adjust mic placement and not have to play the guitar each time. Helps bigtime.
The more you want to do the more expensive it gets. A good ribbon mic is awesome for a "room" mic but you need a mic-pre and the mic. That's going to be $600 for the combo. A shure SM57 is a good start but sounds thin used alone imo.
Wanna do songs? Add in some more instruments and you'll need plugs (FX). Add it up...
