Sample DXF or DWG format schematic
surfsup
Post by surfsup »
Does anyone have a schematic of anything drawn in an engineering software that is a file format DXF/DWG?
I have a software (CAD) but it is not for electrical design. However if someone has something, I can save a ton of work by importing that and taking snippets for resistor/pot/caps, etc and not redrawing them all...
ah, maybe I'll just bite the bullet...
guitarmike2107
Re: Sample DXF or DWG format schematic
Post by guitarmike2107 »
Drop me an email and I can e-mail you some stuff
modulus-amps@uwclub.net
guitarmike2107
Here's two files you can pull some parts from for layouts and for schematics, I have been meaning to create a block library, but just haven't ever got there.
http://www.mediafire.com/?az5gfi2rons22ax
http://www.mediafire.com/?aaxkkuvb9xbiuu1
surfsup
Post by surfsup »
I see people upload files directly to ampgarage. How do yo do that?
overtone
Post by overtone »
to: guitarmike2107
very nicely drawn files! Good work.
to: surfsup,
I don't think Ampgarage accepts a dxf or dwg file uploads.
By the way, did you try JSchem2 for amp schematics? There are nice little libraries there.
But, for amp layout I still prefer to use dwg format CAD - especially where every millimeter counts.
JSchem2 can never compare to a professional programme, yet I find it generates a look and feel that is easy for others to read.
But, if you are used to the power of professional CAD, JSchem2 may be very hard on the nerves. Plus, I could not get a jsch file to upload here either!
Best,
tony
surfsup
Post by surfsup »
guitarmike, those are great. I emailed you the dxf of the vibrachamp I was working on (I'm done now) but it seems you have all that already.
The layouts are great. Thanks so much. Do you have anything with an octal or a tube rectifier?
I'd like to do the CAD layout of the champ I'm going to build. I can post the completed Fender Vibrachamp if anyone wants it. I haven't filled in component values yet so its easy to edit to your liking...
guitarmike2107
Surfsup , Can you send me that file in a earlier version DXF, I cant open it otherwise. I am only running ACAD2004
I will see what else I have that would be usefull for others. most of my parts drawings come from 3d models
Mike
surfsup
Post by surfsup »
I can't seem to figure out how to post a link in a phpbb message to an externally uploaded file so I emailed it to you...
statorvane
Post by statorvane »
guitarmike, your layout components are very cool. 8) I know this took a lot of time to do. Very nicely done, and thanks!
surfsup
Post by surfsup »
Anyone have an octal tube CAD profile? I know the hole is either 1" or 1-3/16" depending on fender or belton, but I'd like the actual mounting bracket/sleeve, etc. I can't find one site that has the 2D profile of any octal. I wish I had a spare octal socket, i'd just measure it!
surfsup
Post by surfsup »
Found the dimensions right after posting that...I'm good. I will CAD this up now.
Cygnus X1
Post by Cygnus X1 »
Very nice...thanks!
Works fine in Autocad 2000i
guitarmike2107
Heres another layout base file you can use the parts from
It has the white ceramic style sockets shown, 9 pin and 8 pin
http://www.mediafire.com/file/bex354469 ... hassis.dxf
surfsup
Post by surfsup »
guitarmike. This is nice too! Looking at the sections, it seems someone was using a solid modeler. Had to have been! Or that is a lot of 2D detail work! I was planning to go to solids with the champ layout I did as well. If these originated from a solid, mind sharing that? 8)
I already did the octal, etc. as per the DIY Champ Clone thread by RJ. Check the last page of that thread if you wanna see what I did for kicks...
guitarmike2107
Hi yes, it was all modelled in Pro-Engineer/Wildfire. I can export to IGUS if you like, that will import into most 3d solid modelling programs.
