talbany wrote:Here is a BIG Problem!!
If you wanted to take this a step further and perhaps ask yourself this? TALKING SS AMPS HERE AND NOW!
In the world of Boutique..
Here we are in 2011 and still cutting and punching eyelet/turret boards here..
Why is a good portion of the general public still hung up on using PCB..
Could it be a fashion statement..
Well, I see it as the hang up is on many levels.
As a boutique builder, unless you want to commit to a specific circuit, pay for CNC programming, use only certain brands of components based on size, and a guarantee you will produce and sell a sufficient number of a particular model, PCB boards do not make sense.
I use a variety of components, build different types of circuits for individual amps, and frankly making a circuit board for each alla a Radio Shack circuit kit doesn't make sense, either.
I can very easily and quickly fabricate an eyelet circuit card adjusted for a change in available NOS signal caps or modern manufacture, etc.
As a sometime amp repairman, circuit boards are harder to work unless you are a contortionist, or in the case of the anemic copper traces found in many PCB of Fender products a masochist. Work on a Vox (Thomas Organ) American Transistor PCB from the 1960's isn't so bad. A cheap SS amp with components to close together so you have to worry about parasitic capacitances, oscillation, and power traces and signal traces to close isn't my idea of fun. And after all the landfill beginners amps that go unloved and unrepaired, SS PCB amps don't have a great reputation.
A vintage amp (Blackface or Tweed) from Fender is easily repaired and maintained.
talbany wrote:
IF so how are you going to get fashion seekers out of tubes when you can't even get them into a well designed PCB.. (You would be shocked to know how many there are out there BTW)..
Well designed PCBs are found in the work of Soul Tone, then again Mickey overspecs his boards to Military and yes in some cases NASA standards.
However Soul Tone also offers Turret Board construction, too. The end consumer drives the market.
PCB are the Industry standard of Military spec, and PCBs built to Mil Spec do have less stress on the components, better mechanical connectivity, and better unit to unit consistency.
Most of the Big Names in Guitars and Guitar Amps, don't build Mil Spec PCBs or use Mil Spec components.
Most consumer product PCBs have in design cost counting as more important than solid workman ship, fastons for connections, possibly machine stuffed (less likely in a smaller builder) using parts designed to be machine stuffed.
Unfortunately, MBAs/bean counters feel that employees are liabilities and the greatest expense to be eliminated at all costs and tolerated only when no alternative.
For smaller builders or beginning builders a circuit board isn't going to distinguish you in the market place.
I can ask and receive a higher price for my amps because I can say, "See? all hand wired using either point to point, terminal strips, turret boards, or circuit cards (eyelets). A musician perceives this feature as durable and built for the road. Thus I gain points as a builder for a quality, and the customer is happy. However, it is just as easy to build a bad handwired amp.
When was the last time if ever a potential customer said to you, "I want it built on a PCB just like Marshall does."?
talbany wrote:
Also looking at it from my bench there really is nothing new under the sun or that has not already been done in tube driven guitar amps since perhaps Ampeg..(sure you could argue built in effects processing)
Well Ampeg was using PCBs as early as the 1950's, however I don't agree entirely with your statement. Since the late 50's one has seen Master Volumes (introduced by Traynor before 1963), Hybrid amps (a tube providing the tone and the transconductance provided by MOSFETS driving OT), Power Scaled Amps (or also known by other name from copy cats), Channel Switching Amps, to name a few. Unless you are familiar with Kevin O'Connor you wouldn't know his gMX circuits or using a single power tube for a push-pull circuit, or 700 watt tube Super Scalers.
On the other hand if you were referring to the original Ampeg SVT, that wasn't as original invention as one would think. From its speaker array to its original use of Transmitting tubes to make a high powered tube amp, Traynor's Super Custom Special preceded the SVT on all accounts. And from what I've heard a Super Custom Special's cab purchased and shipped in from Canada was the origin for the SVT's cabs.
talbany wrote:
So lets say in fact someone does invent a SS guitar amp that rivals that of a tube amp in every way shape and form and has the potential to actually thrive this time around You would have to prove this to those players that have had long perhaps fond relationship with their tube amps.. You would then need vast resources a large marketing campaign an large amounts of MONEY to suceed in swaying the public opinion/fashion.. Even then it's a huge risk!!..I can see the ad now..
A SS amp that sounds just as good as your hand made tube amp.. Yeah that will get them to buy your product!!..
One of the reason SS amps are held in such low esteem is that Fender tried to eliminate its tube amp line by introducing SS versions of the lineup, Twin, Deluxe, ect, the Musicians didn't buy it literally at the time.
Fender's motivation was money. (And to copy Standel amps. Standel had SS amps, and Fender had copied features from Standal tube amps). SS amps do not have an output transformer (a few early exceptions), use lower voltage components, and compared to tubes for rectifiers, pre amplifier (transistors) and power amplifier components cheaper.
And instead of investing money in research and thinking outside of the box (designing class A SS circuits that required big, expensive heatsinks and had less wattage), the basis has always been make it cheap and cheaply made. The thought of using a Cascode of 2 Transistors (to simulate a tube) is just too expensive even when the economies of scale might an extra dollar added to the retail price.
Every Virtual Tube SS tube that has been offered has been for the low end market, beginners market, or for a niche that can't yet afford the lowest price Tube Amp.
With Bugera (Behringer) making cheap, cheaply made tube amp clone knockoffs of Peavey Amps offshore that market is shrinking.
Ampeg made some well made SS amps for their niche market which was basically for Amps to be played clean. I would rather have Ampeg over a Bugera.
talbany wrote:
The BIG problem I see is not so much the invention of such a SS device it's the marketing/financial backing of one that will eventually turn a profit
Until the day comes where someone somewhere design's it then proves it (permanently) and overcomes the perception we continue to stay locked in this somewhat seemingly timeless fashion statement..The longer tube amps continue to thrive the harder it will be to leave them.. IMHO
A SS innovation would be newsworthy and thrive, but don't count out the Tube amp.
Tubes have been around since before 1907. The 6L6 has been around since 1936. The US and Europe stopped production in the 1980's. That was going to be the end of tubes.
Many tubes have outlived the original transistors that were supposed to replace them.
The Transistor market currently is driven by switching device uses (for power supplies MOSFETS) for computers, cellphone technology, and consumer grade TV sets and 5.1 speaker systems, portable MP3 players, computer (other components) IPads, Digital, etc Transistors aren't going to disappear.
The Audiophiles and the Musicians wouldn't let Tubes die as a consumer product (Tubes were still being used for TV transmission and Radio Transmission) because of the tone.
Most of the rest of the world (and un-initiated) doesn't know or couldn't care less about the difference between SS and Tubes. They couldn't afford to have Tube audio, nor would it be important, too them. Analog reproduction is an unknown or maybe they might remember VHS Hi-Fi as their sound source and couldn't care less (because of not experiencing the positive factors of tubes).
Sound Quality and High Fidelity just isn't even in the running for transistors, except for maybe in Japan's domestic market. Tube amps still dominate the field for audiophile sound.
(I can get about 600 bucks for my 1960's tube amp, and if I had a MacIntosh tube amp, I could get thousands. How many SS integrated amps from the 1960's 1970's 1980's can command that price?)
The audio world of the masses is driven by Walmart purchasers purchasing Surround Sound for their DVD player.
As I said, Tubes have outlasted many of the original SS offerings meant to replace them. I have to go to NOS surplus dealers around the world to find certain transistors that were made in the 1960's-1990's and no longer in production.
talbany wrote:
I would bet you my left one someone out there has actually designed and built one too ..
MONEY and war is the driving force behind technology and in the end what gets handed to the masses..
If one could design transistors to do what a tube does and with incredible variability of a tube, and built a product of your dreams, there would be a market. However with so many failed attempts to market/promote (lie) about a product as being equal to a tube amp and wasn't, most musicians are skeptical.
Best Regards,
Steve
