PI Trimmer
PI Trimmer
Silly question, but I want to add a trimmer/balance to my PI. Where do you guys buy those mini potentiometers, and what value and rating do you recommend? Thanks for any advice!
Re: PI Trimmer
I like these Piher trimmers.
I prefer the horizontal mount/ vertical adjust because I have slipped off of a vertical mount one before and got shocked.
In other words, I like the screw driver to be vertical into the trimmer.
(best to use non conductive screw driver as well....)
http://www.mouser.com/ProductDetail/Pih ... FOmbu/U%3d
This is a 10K, supposedly if you use a larger value it gives a bit more headroom. I haven't experimented with it enough to know.
Dumble used the vertical mount/ horizontal adjust if you want to be true to the design.
Re: PI Trimmer
This job needs a non-metallic tool. I like to use a 12" bamboo skewer with the end whittled into a flat blade. The extra length means you can get the angle you need to adjust a vertical trimmer with your hand outside the chassis.Structo wrote:I prefer the horizontal mount/ vertical adjust because I have slipped off of a vertical mount one before and got shocked.
Re: PI Trimmer
A 10-turn trimmer makes it easier....
There are no stupid questions, just stupid people.......
Re: PI Trimmer
Thanks to all. Tom, is 1/3 watt a high enough rating for the PI. This is what I was unsure about.
- David Root
Re: PI Trimmer
Martin, that is a good idea on the trimmer adjusting tool. Cheap too! I have been trying to use a wood spudger with flathead crewdriver shaped tip but it's too wide, I guess I should narrow it a bit.
Re: PI Trimmer
Yeah, there is very little current on that trimmer, so it is safe.Sonic wrote:Thanks to all. Tom, is 1/3 watt a high enough rating for the PI. This is what I was unsure about.
Re: PI Trimmer
This one of those crazy questions. Sonically, (okay a little pun intended) what does the 10K do?
Does it effect the tone of the amp, or is it done to get maximum headroom from the amp?
Yours Sincerely
Mark Abbott
Mark Abbott
Re: PI Trimmer
It's a tone thing. With equal plate loads the LTP phase inverter doesn't have balanced (equal amplitude) outputs from the inverting and non-inverting sides, and so ultimately the distortion and harmonics of the speaker output are affected. Using fixed plate resistors that are miss-matched (82k on the inverting and 100k on the non-inverting triode, e.g.) is a common solution; adding the trimmer provides a way to fine-tune the result.Mark wrote:This one of those crazy questions. Sonically, (okay a little pun intended) what does the 10K do? Does it effect the tone of the amp, or is it done to get maximum headroom from the amp?
Re: PI Trimmer
Always great info here. Thanks to everyone!
Re: PI Trimmer
Thanks for the reply, much appreciated.
Dare I ask how most people adjust this pot, is the effect subtle or easily heard?
Yours Sincerely
Mark Abbott
Mark Abbott
Re: PI Trimmer
Do a search. It's kind of subtle, and there is more than one way to go about it. Here's a start:Mark wrote:Dare I ask how most people adjust this pot, is the effect subtle or easily heard?
https://tubeamparchive.com/viewtopic.ph ... g++trimmer
