Grounding for the least hum
jcat5503
Post by jcat5503 »
I'm a curious about this
What's the "best" way to do grounds to ensure minimal hum?
Cheers!
mlp-mx6
Re: Grounding for the least hum
Post by mlp-mx6 »
I do not think there is "the one answer" to your question.
What circuit are you implementing?
Me: Just one more...
jcat5503
Post by jcat5503 »
cathode biased el84 circuit
Ken Moon
Post by Ken Moon »
Normster
Post by Normster »
According to Morgan Jones, "Signal follows earth (ground)." In his book "Building Valve Amplifiers" he briefly discusses that the grounding scheme pretty much follows the amp layout. If you use star grounding, the amp tends to be layed out around the star ground. If you use bus grounding, the amp layout tends to be long and narrow. For what it's worth, I typically use a 14AWG bus bar grounded close to the input jack. All preamp stages go to the bus. Preamp filter caps ground to the same ground point as the bus. Mains (plates and screens, bias) filter caps ground closer to the PT. Works for me but others may have better layouts.
briane wrote:... it really is a journey, and you just can't farm out the battle wounds.
