wire tie
selloutrr
wire tie
Post by selloutrr »
Does anyone have a link to teach the wire wrap technique using string like found on british amps.
My Daughter Build Stone Henge
Re: wire tie
It's pretty easy.
Sort of a half hitch or blanket stitch.
My dad was an old school telephone repairman for Ma Bell for 35 years.
He used to bring equipment home that was going to be thrown out because it was outdated.
I remember well cabinets with wires that were bundled like that.
The string they used was a waxed linen string. My dad used to have several rolls at the house. Don't know what ever happened to it.
Most of the old telephone equipment was made by Western Electric and those guys built some high quality stuff. I dare say mil spec all the way.
I was always impressed by what I saw from them.
selloutrr
Re: wire tie
Post by selloutrr »
Perfect Thank you!
It looked pretty easy I tied flies when I was younger.
I'm thinking of working it into a new build.
I like how neat it makes the finished look.
ToneMerc
Re: wire tie
Post by ToneMerc »
Structo wrote: The string they used was a waxed linen string
Yep, the telco type string is actually called AT&T lacing cord. I was taught by Bell guys and have done wire running and lacing in telco CO environments. I've only done it a couple of times in amps. I've found that the #9 waxed cord doesn't work as well for the smaller diameter wires that we typically use inside of amps. The next time that I try it I'm going to use some Spectra fiber braid that I have on hand.
TM
passfan
Re: wire tie
Post by passfan »
TM
You are correct, it is called lacing. I was taught how to lace back in I&C school in the early 80's. I haven't seen it done since though I've popped a few organ amps that had it in them.
"It Happens"
Forrest Gump
surfsup
Re: wire tie
Post by surfsup »
Okay I have to ask, I have been told to not do parallel runs of leads but this seems like leads being tied are making one huge parallel run. So what is the purpose and why would you want to run lines like this?
ToneMerc
Re: wire tie
Post by ToneMerc »
surfsup wrote:Okay I have to ask, I have been told to not do parallel runs of leads but this seems like leads being tied are making one huge parallel run. So what is the purpose and why would you want to run lines like this?
You have to keep in context that different (RF, AC, DC, ethernet...etc) cable signal types are still segregated. This wiki explains some important reasons why.
http://en.wikipedia.org/wiki/Cable_lacing
I used a very small amount of lacing here.
https://tubeamparchive.com/viewtopic.ph ... ight=jtm45
TM
RJ Guitars
Re: wire tie
Post by RJ Guitars »
I learned most of amp building from a group of guys that were really into HiFi. They didn't really like the wire tie bundling technique so much but did say that "if" you wanted to tidy things up by bundling wires, Dental Floss was the preferred product.
rj
http://www.rjguitars.net
TheGimp
Re: wire tie
Post by TheGimp »
You can still buy waxed nylon lace specifically designed for this purpose. I have both white and black. If you want to know the technique, look for military procedures for lacing wiring.
I learned it in the NAVY in the early 70s and still use it today to bundle HT wiring, but not much else.
