Turning "off" One Tube in PP Output Stage
ChrisM
Post by ChrisM »
Ok I am trying to turn off one tube in a dual 6L6GC fixed bias output stage.
This is my idea...
[IMG:720:450]http://img.photobucket.com/albums/v610/ ... s/Idea.jpg[/img]
(used EL84s for illustration purposes)
It comes from the Dumble half power switch as seen here
https://tubeamparchive.com/files/124_schematic_182.pdf
Basically it shut "offs" one tube so it isnt doing much. But it is still technically on but little current flows through it. This way the primary impedance is kept the same.
Will this work, any other ideas, insight, comments?
Thanks...
ChrisM
Re: Turning "off" One Tube in PP Output Stage
Post by ChrisM »
Like typically 50W output stage.
One tube's plate to the OT, the other end of the OT goes to the other tube's plate.
dynaman
Post by dynaman »
Have you heard a P/P amp with one tube pulled? Are you simply trying to lose power?
ChrisM
Post by ChrisM »
I have not, care to explain for me?
Would my idea work?
dynaman
Post by dynaman »
Crossover distortion, I'd imagine. Honestly, I don't know all of the different parameters that would be upset. You'd only be amplifying half of the PI's signal, but your output wouldn't be 25W. It would be significantly lower. I've ran a P/P amp with only one tube for non-playing purposes and it sounded wretched. I'm sure others with more technical experience will chime in with the particulars of what would happen.
Of course you could conceivably pull an output tube from an amp that was running in parallel SE.
If you turn one tube off what you will have left is essentially a single-ended output stage biased really cold, near cut-off, resulting in lots of distortion.
Richie
Post by Richie »
and sounds like crap.
ChrisM
Post by ChrisM »
I am going to experience what crap sounds like first hand than. Thanks for the info...
dartanion
Post by dartanion »
A better approach would be to leave the tube in the circuit and cutoff the input signal to a tube.
selloutrr
Post by selloutrr »
consider using a 4PDT or of the like and adding a bias adjustment to compensate for the "crap" of removing one tube.
My Daughter Build Stone Henge
Dartanion, I think the result would be about the same. Chris, if you're trying to reduce volume you could add the so-called Lar-Mar post-PI master volume. Do you know that one?
daydreamer
Post by daydreamer »
I was just reading about the Mesa Boogie Lonestar (I think) and they have a 'patent applied for' way of doing this, so, yeah, not sure about getting specifics, they are all PCB as well.
Basically it is the 5W setting on the Lonestar changes the amp from p/p to SE (on one tube obviously).
Excuse the newbie trying to sound smart here, but the phase splitter would have to be bypassed yeah?
Sounds like a worthy cause....
"Too young to know, too old to listen..."
Suze Demachi- Baby Animals
selloutrr
Post by selloutrr »
they may have a circuit that flips the 180 degree out of phase in phase when it's not PP. much like combining the wet / dry signals so you don't have volume loss.
If it's mesa I'm sure it's no secret's and has probably been done before they just patten everything they do, I'm not sure how many of the pattens hold water... most are enforced with $$$ muscle.
ChrisM
Post by ChrisM »
I am not trying to reduce output level. There is a million and one other ways to do that :D .
It was more trying to do "class A" emulation. A friend had told me Mesa did "something similar" so I was just wondering.
