Here is a picture of my chassis, with a test-faceplate made of regular paper. It fits nicely, so I ordered the vinyl print. Can't wait to get started on the mounting.
Tommy
						Finally getting started
						Re: Finally getting started
Dale, what program did you use to make the faceplate? i gotta do this to my amps.. even in paper it looks better than this..
http://mywebpages.comcast.net/roadrebel/faceplate.jpg
P.S. don't pick on the snakeskin, was like that when i got it:)
Hey man, you're leanin on my dream......
I use Adobe Photoshop. Probably not the best program for this kind of job, but it worked out nicely.
When I drilled the holes for the pots and switches, they didn't line up 100%.. I should have used a drill press, but didn't have one at the time, so I did it with a regular drill. Therefore some of the holes got a bit out of line.
What I did then, was that I took a picture of the chassis front, scaled it up to the exact size of the face plate photo file. I then made the chassis layer transparent, and I adjusted each ring of numbers to fit where the holes actually are located. I'd be happy to send you the files of my face plates, if you'd like me to..
Tommy
Tommy
