pamaz67 wrote:unfortunately there are lot of Power transformers that have a less than desirable regulation, therefore the voltage they deliver on full power request is sometimes 10 - 15% less than the idle one.
Myself, have been facing similar problems with some Twin replacement transformers coming from one of the "well reputed" supplier.
As a result, I had to replace all of these irons with some other ( better ) stuff.
The only thing I can imagine, is to use them on low powered amps. Or use them to lock the door open....
Lets' say that I have four power transformers rated for fender twin that are going to be used on 50 watters. The amp was not able to do more than 65 w at 5% distortion with that stuff.
Paolo
paul at mercury magnetics told me that the heyboer power transformers voltages brown out under load... and tried to talk me into his PT... is this what were talking about?
No, I'm not referring to heyboer that per my experience are really good stuff.
Paolo
Paolo
thanks, I like them too... except the heyboer PT's can be noisy acoustically.. never tested the brown out theory.
