Yes I can give that a try.Do you have a 12AY7 handy?
Stock tone stack with the addition of a 25KL Midrange pot in place of the 10K resistorHow are you running the tone stack? Have you tried adjusting the midrange?
I've done that to some degree, but V1 is still low (75V - see below).If V1 voltages are low, you might adjust the dropping string to bump them up.
Current PS Rail Dropping Resistors is as follows: Choke-18K-9K1-4K7
I'm currently running a 68K instead of the 56K.The cathode follower is stealing current from the previous stage, adding some gain to it. To reduce compression a little, you could try increasing the 56k cathode resistor on the cathode follower up to 100k.
two matched pairs of JJ EL84 (matched quad on order)What el-84s are you using?
Embarrased to say yes, picked up a Techtronix 453 on eBay a couple years ago, and *still* haven't learned how to use it.Do you have a scope?
Here is a full set of voltage readings. V1A plate was actually in the 80's last time I measured. I've been swapping tubes around since, and now it's down around 75V.
VOLTAGES:
AC Mains: 123.2
PT HV: 517 VAC
B+ (plates): 305
B+1 (screens/reverb driver): 295
B+2 (PI): 218
B+3 (V2A-CF): 187
B+4 (V1, V2B-Reverb Recovery): 182
V1.1: 74.4
V1.2: 0
V1.3: 0.72
V1.6: 114.7
V1.7: 0
V1.8: 0.97
V2.1: 187.8
V2.2: 114.4
V2.3: 114.8
V2.6: 126.5
V2.7: 0
V2.8: 1.23
V3.1: 292
V3.2: 0
V3.3: 2.36
V3.6: (292)
V3.7: (0)
V3.8: (2.36)
V4.1: 166.6
V4.2: 27.3
V4.3: 42.9
V4.6: 177.9
V4.7: 29.5
V4.8: (42.9)
V5 and V6:
Pin3: 9.0
Pin7: 295
Pin9: 295
V7 and V86:
Pin3: 9.0
Pin7: 297
Pin9: 295
Anything jumping out...?
