Little wing parallel stages/ Nasty distortion
chopstuck
Post by chopstuck »
I built Geezer's Little Wing with Hammond AO-44 iron. It's a fun project, small cheap and a little challenging. I dropped the EZ-81 and used SS rectification to get enough heater current to run two additional 12ax7's. I then dropped the incoming DC with resistors to match the EZ-81 internal resistance.
The circuit is basically a plexi pre into a 6BM8 push pull power stage.
Problem is I now have nasty distortion coming from the preamp. It's there even when the MV is turned down to 1 or 2. I have the first two stages parallel on a common 1k5 as in the schematic. I wondering if I need to juggle this stage or if the is a way to tell if the problem lies in stage 2 or 3.
Heavens, an unused PI input !
10thTx
Re: Little wing parallel stages/ Nasty distortion
Post by 10thTx »
Here is the schematic. I built one also with reverb. It did not have a nasty distortion at all.
with respect, 10thtx
chopstuck
Post by chopstuck »
Never mind, I fixed it.
This must be the psycho-ampo-therapy forum. Just putting problems onto the net helps me solve it, as if someone had asked me the very same question.
Was just a NFB set up problem.
I really like this amp. So much so I've built two of them. One with reverb and one without.
I can play it for quite a while through a Vox alnico blue with little ear fatigue. Still plenty loud through an efficient speaker though.
Next stop - more amps with 6BM8 outputs.!
10thTx
Post by 10thTx »
Well, if you're wanting to try another 6BM8 amp. I built this one also & liked it even better than the Little Wing.
With respect, 10thtx
soundclip here: http://www.soundclick.com/player/single ... i&newref=1
You guys ever use the triodes in the 6bm8?
FYL
Post by FYL »
They are similar to half a 12AT7. Purrfect for a PI or a reverb driver or...
Well that is what I was wondering about, seems a waste to not use them but I wanted to hear if possibly it was a noise issue and that is why they aren't used.
da Geezer
Post by da Geezer »
Structo,
If you look closely, you'll see that the 6BM8 triodes are used (in both schems posted by 10thTx) as the LTPI.
As FYL stated, similar specs as a 12AT7.
Geezer
chopstuck
Post by chopstuck »
Yes, I used the triodes in both my builds. Not terribly noisy that I can tell.
Tell me Jeff, Does your 56T amp use the reverb unit PT ? Is the preamp modeled after anything like a Sunn ?
DOH!
Just ignore me..........
10thTx
Post by 10thTx »
The 56T uses a WeberVST Deluxe Reverb PT & OT.
I don't know anything about Sunn amps. The 56T was based on DaGeezer's HoSo56 amp design.
