Layout 5th Generation 183
talbany
Post by talbany »
OK everyone here is the final layout for the archive..#183
A 5th generation ODS with mid switch - 3 piece chassis,(wooden sides high plate no LNFB V1 Skyliner w/different script
Also a big thank you to Shad/ Quinn amps for all his help with the layout..without it it would not be possible..
Shout out any errors you see..Enjoy!!
jborders5
Re: Layout 5th Generation 183
Post by jborders5 »
Thanks for your efforts Tony. This one is on my list as a winter build.
http://agbamplifiers.com/
Dumble Clone Circuit Boards
talbany
Post by talbany »
jborders5 wrote:Thanks for your efforts Tony. This one is on my list as a winter build.
Thanks Jason
Hey Shoot me an email talbany@vvtamps.com I need your e-mail and want to run something by you.. THX
Teleguy61
Post by Teleguy61 »
Beautiful work Tony.
Your generosity is very greatly appreciated.
George
ChrisM
Post by ChrisM »
Damn that looks good, wish I had your skills.
Thanks!
David Root
Post by David Root »
Thank you once again Tony! Great work, you have really mastered that software!
Reminds me I have to put a label on the backplate of two of my amps, "DO NOT USE EL-34" (Pin 1 carries screen grid resistor to pin 4).
dogears
Post by dogears »
Very nice! Big thanks to you and Shad.....
A few observations..... The resistor from the .005 OD2 cap to the drive pot seems to be a 180k in my pics. It is quite clear in fact. Can we check that value??
Also, are we sure that the OD Volume pot is also a 250K? In my notes from Shad, I have 100K written. Then again, I was not told the cap on the bass pot was a .0047uf ;)
Thanks!!
ampdork
Post by ampdork »
I have been lagging on checking out Tony's layout.
There was a lot of things to change with the first revision, so there are surely a few things to iron out...Tony sent me this revision to check before posting but I have tied up with some other business stuff.
As soon as I get time today I'll go over this new one and verify.
Any other questionable spots please do mention so I can double check.
"...& I'm all out of bubblegum"
dogears
Post by dogears »
Thanks bro!!!
ampdork wrote:I have been lagging on checking out Tony's layout.
jborders5
Post by jborders5 »
Thanks Jason
Done. Let me know if you don't receive it.
talbany
Post by talbany »
Shad
Check out the one I just posted not the one I e-mailed you as it is more accurate.. Thanks for looking it over..
Jason I got it thanks I'll be in touch soon
Something I just noticed on a picture of this amp, HAD mounted the preamp sockets with the gap towards the board.
In other words, pins 4 & 5 are towards the rear of the chassis, unlike #124.
Bob-I
Post by Bob-I »
Structo wrote:Something I just noticed on a picture of this amp, HAD mounted the preamp sockets with the gap towards the board.
Yes, because pins 6-7-8 are the first triode, 1-2-3 are the second triode. He positioned the tube this way to correctly use these triodes.
http://www.tubezone.net/pdf/12ax7ecc83.pdf
Scroll down to page 7 "Base connections"
talbany
Post by talbany »
Tom Bob
Guy's if I really thought that would effect the tone in any way shape or form I would be all over it....Personally I think cap orientation is more important.Thanks for the shout out though..
jborders5
Post by jborders5 »
Has anyone found a source for 330uf axial caps? I'm not aware of any current manufactures, but haven't researched it much. One option is using a "Snap In" style cap and extend the leads. They're readily available and cheap . Mouser carries Panasonic, Nichicon, Cornell Dubilier, etc. and most are around $6.00 each. They should work with most Precision Power Supply boards as long as the height/length isn't much over 30MM. The attached .jpg is to scale. Any thoughts to if this is a viable option?
[img:800:682]http://img254.imageshack.us/img254/4142 ... snapin.jpg[/img]
