are these? For some reason they look different to me, but maybe I am wrong.
v846 responded to another post of mine, and this is a pic from one of his amps (hope he does not mind). I am not sure why, but the turrets look different than most others I have seen. Maybe there is no hole in the top......?
https://tubeamparchive.com/download/file.php?id=14050
What kind of turrets.....
Cliff Schecht
Re: What kind of turrets.....
They are like what RJ uses. They don't have holes because someone filled the top of them with solder!
Edit: Actually I don't recall if those are what RJ uses, but they are definitely what are used in this: http://www.tubesandmore.com/scripts/fox ... =P-HTUR-60
Cliff Schecht - Circuit P.I.
guitarmike2107
http://acimg.auctivacommerce.com/imgdat ... 310854.jpg
They are vintage style slotted turrets.
Available from RS components too if you can find them.
Michael
Michael
I agree with GuitarMike, they look like the split turrets that I used on my last Marshall build, you can get them here.
http://www.turretboards.com/circuit_board_terminals.htm
