Does any one know anything about the orange "dips" caps sold by justradios.com?
http://www.justradios.com/capkits.html
I can't get a clear answer from the owner, does anyone know if these are the same as the Mallory PVC6** caps?
Eric
Orange "Dips" ????
Re: Orange "Dips" ????
it's possible
specs:
Construction: Highest quality poly film construction. Under 0.01uF are PNN Polypropylene Metal-Foil construction while 0.01uF and above are DME Metalized Polyester. These metalized poly film Orange Dips are made by ISO 9002 & 9001 certified manufacturer / OEM supplier to CDE Cornell-Dubilier, (Cornell-Dubilier), HP, Sony, Canon and Bosch.
Use: Excellent for DC blocking, coupling, filtering and by-pass in tube radios, audio and guitar amps, hi-fi, communications equipment and general electronics. Superior replacement for paper/wax capacitors in tube electronics.
Features: Rated at 630 Volts; Extra long (30mm) copper-ply radial leads; non-inductive construction; good solderability; Compact body size; Orange epoxy dipped for superior heat, moisture and solvent resistance.
http://www.justradios.com/DMEcapacitors.html
specs:
My Daughter Build Stone Henge
Coat these in orange epoxy and call them "Dips"
http://www.etr.com.tw/eng/dc_use_film_c ... c01_04.htm
TM
TM
- KindaFuzzy
I'm not sure if they're exactly like the mallory ones or not, but they are much smaller than sprague orange drops or even the yellow mallory caps. I use them all the time, and the yellow tubular caps he sells are excellent and super cheap too. I buy all my coupling caps from him, highly recommended, and try some of the polystyrene's he's got too.
Check out my amp gallery: http://www.flickr.com/photos/35422385@N07/
And new website: http://koamps.weebly.com/index.html
That's good to know. I came across him as being the just about the only vendor I can find selling a 10 x 10 @ 500v can which the Dumble 124 calls for.I buy all my coupling caps from him, highly recommended
RJ sells the Mallory caps, he's got to get them from somewhere!
Eric
Used them and their other caps and resistors many times, great stuff, good quality.
Website claims they are 225P series. These are good quality polyester caps.
Jelle
Jelle
Markusv
Use them all the time too
Have used other caps from other vendors too- but this guy is consistent, well priced, helpful , ships fast etc
Like his resistors too
He told me once that the caps are made for (or by) Cornell -Dubilier. Not sure if I understood correctly
He also sells green mylars in bulk and I've tried them- they sound surprizingly good!
Markus V
Markus V
.........Now where did I put it?
Made by ETR in Taiwan, who also supplies Cornell-Dubilier (and numerous others) on an OEM basis. Same caps, different markings.He told me once that the caps are made for (or by) Cornell -Dubilier. Not sure if I understood correctly
