Billion81 wrote:Are you implying that by deviating from the given Dumble circuit (let's use #40) by adding or modding with ideas from a different era or circuit is less of a tone generator than a carbon copy build piece for piece?
Hi Ted,
no, it is not "
less of an tone generator" IMO, but a
different one. Let me try to explain it by using an example: Scott pointed out in the Two Rock Artist thread lately that a usual skyline circuit like #124 is not able to recreate the tone of Robben Ford's "green light, green switches" ODS in its current version because it does not have the special skyline circuit variant of RF's current amp ("the Ojai tweaks"). That is what I am talking about.
So this is my opinion:
If you want to build a "tone replica" of a single Dumble amp - RF's green light, green switches ODS as an example - I would recommend not to build an amp with the #13 PI, mix this with the #124 tone stack, then add the EL34 power amp of #183, the OD entrance of #040, the V1/V2 plate resistors of #123 etc. Instead of this I would recommend to start your build with an exact copy of the single specimen, like the Ojai is obviously an exact copy of Robben's green light amp and the Hi-Plains Drifter an exact copy of EJ's SSS. And then I would start tweaking from there according to your personal taste.
(And BTW: because Brandon has this IMO very reasonable approach, I asked in my opening post, if someone here perhaps knows if his "70ies circuit" amp is perhaps an exact copy, too, and if so, of which amp or generation precisely. And I did not ask himself in an e-mail, because at this moment I don't plan to order such an amp. And I would think it to be not that polite to monkey around with his time, busy as he is building up his business, just out of personal curiosity. And I did not see any reason at all for any "secrecy" concerning these pics I've posted, because these had already been posted before by his customer on "The Gear Page", a site far more frequented than this one - in particular by all his competitors, too.)
And if after your tweaking process you should end up with such a kind of mixture as described above or even with a version of a Hiwatt and this does exactly what you want, then I personally would not care at all if this "personal cocktail" of ingrediences out of say 43 different amps is still "original" or not, as the only thing that matters IMO is, if this mixture pleases you, period.
But indeed I would not recommend to
start this "tweaking process" with such a kind of "Dumble cocktail" - just because I personally have my doubts that this would be the most promising starting point.
So if you want to build a "tone replica" of such a 2nd generation ODS, I would recommend not to mix the bright switch value of #02X with the "James configuration" of #03X, the V1 and V2 grid resistor values of #04X, the OD entrance network of #05X etc.
All these specs are IMO parts of the individual tweaking of the individual amp. And IMO the opinion of marcos that the amps Dumble exported to Europe have not been tweaked by him is not correct. If Alexander by whatever reasons should not have wished or been able to tweak them according to his taste, why then all these tiny differences? In this case it would have made far more sense concerning workflow to build all these amps in the very same way and with the very same parts.
And because these "export" amps IMO have been individualy tweaked by Alexander, too, IMO these 2nd generation amps are all "individual tone generators", too - including the exported ones. And because of this I would recommend to start either with a clone of #02X, or with a clone of #03X, or with a clone of #04X, or with a clone of #5X but not with any kind of "2nd generation cocktail". If this should not be possible by whatever reason, then of course some kind of "mixture" would still be a better starting point than no starting point at all.
Max
