BIAS Voltage problem!!!
Re: BIAS Voltage problem!!!
Why run the bias so low, get some heat going and let that amp sing.
grtamp
Post by grtamp »
if I change 51K tail res to low value I take about -46/-50V and the current going up 44mA and over.
37mA with 450plate voltage for me seems good , maybe 2/3mA more.
yeah you are only running about 30 watts at that bias but these amps do like a colder bias than others.
kd
Post by kd »
I'm running winged =C= tubes and to me they sound better biased fairly hot. I usually run them around 70%. The amp had TAD 6L6WGC tubes and I like them better with a lower bias. Not trying to be argumentative, just an opinion.
Ken
Once you set your bias range let the amp idle then play the guitar and listen to where you think it sounds the best.
See where the meter is at and I bet your in the specified bias range plus it sounds good to your ears.
kd wrote:I'm running winged =C= tubes and to me they sound better biased fairly hot. I usually run them around 70%. The amp had TAD 6L6WGC tubes and I like them better with a lower bias. Not trying to be argumentative, just an opinion.
Ken
TKT
kd
Post by kd »
Tom,
I'm not the sharpest knife in the drawer, what does TKT mean?
Ken
TKT
Tag Knows Tone
grtamp
Post by grtamp »
I'm running SVETLANA WINGED "C" also , but I found different current absorption in vary stock I have.
Sorry it was a lame attempt at humor. :D
kd
Post by kd »
Sorry it was a lame attempt at humor. Very Happy
I figured it was something humorous, sometimes I'm slow on the uptake.
Ken
