I have a Traynor guitar Mate 4 with a nasty stock reverb. Is there any way to make this sound better without converting to a transformer coupled design ?
And if converting to transformer coupled will I have to get a different tank ?
What would be the DCR of an appropriate tank for a Fender style reverb trans ?
Any way to make a capacitor coupled reverb sound good ?
Heavens, an unused PI input !
Re: Any way to make a capacitor coupled reverb sound good ?
What is the offending characteristic of the reverb sound? Has it ever sounded good? Maybe a bad tube or a failed component in the circuit?
One of the best reverbs that I have ever heard is in an Ampeg V4 which is capacitor coupled as well. You could check out that schematic for similarities and differences with yours. I know that it uses a 6CG7 triode driver as opposed to the typical 12AX7.
The "standard" Fender circuit uses a 8 ohm output transformer and a tank with an 8 ohm input/2250 ohm output rating. Those are AC impedance values which are quite different than DCR values.
Not sure if your tank can be used in a tranny coupled circuit. Consider Googling the P/N for it's ratings. You might be able to find a transformer that would make it work in your existing circuit.
Good luck!
Dave O.
Good luck!
Dave O.
I came across this table at the Accutronics site that provides cross refrences to DCR. Hopefully that will help to define what you have.
Dave O.
Dave O.
Andy Le Blanc
Use a 12au7 SRPP instead of the paralleled 12ax7.
lazymaryamps
What Andy said.
If a pan is driven direct from the tube, it has to have the right input impedance for impedance matching to work. See here:
http://www.freewebs.com/valvewizard2/reverbdriver.html
and here for setting up the SRPP stage:
http://valvewizard1.webs.com/srpp.html
