5e3 input jack wiring
ampmike
Post by ampmike »
Hey Guys,Im having a little trouble with the input jacks on a mojo 5e3 build.
My son built it and I ripped out the board later to beef it up,beter caps ,components,ect.The wiring on the input jacks on the layout are not very clear.Is there a picture or a clear diagram anywhere?I believe these are switchcraft jacks,Thanx Mikey :oops: :oops: :oops:
Re: 5e3 input jack wiring
Here's a nice layout, courtesy of Triode.
labb
Post by labb »
give this a try
How to wire Hi/Low input jacks - Cliff and Switchcraft types
over on the hoffman board
ampmike
Thanx
Post by ampmike »
You guys are awsome,Thanx ,Very helpfull!!!
Make sure you confirm tip, sleeve and switch. There are lots of knock offs floating around that don't always have the same order to the terminals.
tubeswell
Post by tubeswell »
Steve Ahola (blue Geetar) has some pics of one of his builds here including handy tips for wiring input jacks.
http://www.blueguitar.org/new/articles/ ... y_5e3a.pdf
I use a similar method of direct wiring the 68k and 1M to the input jacks followed by shield cable to V1 grids. I mount the jacks inside-out on the chassis first to get the pairs lined up and then install the resistors and cables solder them in in pairs to the jacks, and then undo them and put them in the right way around and solder the cables up to the V1 grid pins JM2CW
