Dimenson Dumble masterboard, eyelet board size
glasman
Re: Dimenson Dumble masterboard, eyelet board size
Post by glasman »
M Fowler wrote:Some fabric shops have all the various eyelets you just have to hit the yellow pages and hope the person answering knows what your talking about.
Virtually all Joann stores carry a brass 1/8" eyelet that is almost exactly the same as the Keystone eyelets.
Take a look at you local scrabbooking store, they all have eyelets of various sizes and the tools to set them. Cheap
Gary
About 5 miles south of I-94
www.glaswerks.com
danotron
Post by danotron »
I get my eyelets at the Dollars store.......super cheap...and they work well
The Blues is my Business....
and Business is good.....
EL34
Post by EL34 »
Hoffman charges $14 minimum for shipping to Canada.
Hi all,
Just noticed this thread.
Don't want to hijack or advertise, but just in case someone needs a source for 1/8" thick G10 board material.
I ship board to Canada and all over the world every day.
Actually, it's only $13 for a flat rate envelope shipment to Canada and Mexico.
$15 for the rest of the world. $6.95 for the US.
But, the board can be no longer than 12 inches to fit in the FR envelope (Flat Rate Envelope)
And, I can't ship anything tall or crushable with a 12" piece of board.
If I stick a tube socket or pot in there, it would be destroyed.
I can ship flat, non-crushable items in the FR enevelope with the board material.
Turret lugs, eyelets, standoffs, switches, wire, knobs can all be put in with the board material.
Non polarized small caps like sprague, mallory, Xicon are good to go also, but I would not ship a electrolytic can cap like a sprague 20/500v without it being in a box.
The way I normally ship parts using the Flat rate envelope is to put all the parts in a small box and then put that in the FR envelope. I can't do that with a piece of board longer than 9 inches, but a ton of small parts fit in a small box/FR envelope.
I have a ton of info with pictures of the shipping containers here.
http://www.hoffmanamps.com/Info/ShippingInfo.shtml
Is there an eyelet or turret board version for the FET board rather than PCB?
For the #124 layout/schematic Tony and Martin have posted.
Okay so For the #124 I can use this FET board correct?
Ceriatone has a version which you can access from their site:
http://www.ceriatone.com/images/layoutP ... iatone.jpg
Martin, thanks I was trying to stay away from the Ceriatone but why reinvent the wheel I guess.
Sometimes I wonder why I didn't just get a Brownnote or Ceriatone kit and save myself from the parts chase headaches. :)
ToneMerc
FET eyelet board
Post by ToneMerc »
Made this FET board yesterday based on the Ceriatone layout. I'm going to mount it in the rear corner of the chassis.
About the only thing I have on the FET is this layout, which I believe is really for a PCB.
mdroberts1243
Post by mdroberts1243 »
Structo wrote:About the only thing I have on the FET is this layout, which I believe is really for a PCB.
This is the layout from the little ExpressPCB project I did... never tested. The files are attached somewhere... attached again here.
-mark.
My tube blog & link directory: http://tubenexus.com
Cause & Effect Pedals FET Dream and Dumble Style Chassis
ChrisM
Re: FET eyelet board
Post by ChrisM »
ToneMerc wrote:Made this FET board yesterday based on the Ceriatone layout. I'm going to mount it in the rear corner of the chassis.
70s style!
Where are you getting the smaller (diameter) 1/8" eyelets?
Thanks for the information guys.
ToneMerc
Post by ToneMerc »
70s style!
Mouser, I used 3 sizes, .093 long as the board is 1/16" thick.
large: 1/8" x .093 #534-43
med: 3/32" x .093 #534-33
sm: 1/16" x .093 #534-23
I also use the 1/16" x.093 for the relay sockets and 3/32" for the outboard connections..
gary sanders
Post by gary sanders »
I see some of you posting that you get eyelets from craft stores.the only ones i can find have some type of plating or finish on them that solder doesnt bond to.is there a major chain of stores in the US that sells eyelets like I need for a board?
tubedogsmith
Post by tubedogsmith »
Why not just get them from Mouser or Hoffman Amps?
